Very HOT Calipers
Very HOT Calipers
I have a 96 EB, I just when thru a pair of brake pads and warped a pair of rotors in 7 months, I replaced both so that not a problem, but my question is does any one else have calipers that get super hot to the touch after driveing maybe 30 miles wil braking, I thinking I'm going to need a new set of calipers, but any thoughts ....
TIA
-Will
TIA
-Will
Originally Posted by Jdenninger
how are the rear brakes? it seems like your truck is only using the fronts to stop. I would check and make sure the rear brakes are adjusted and working properly. just my .02
Jeff
Jeff
only thing i can think of is to raise the rear tires off the ground set the parking brake, chock the front wheels, put the truck in nuetral and try to turn the wheels by hand. if they turn chances are the brakes are adjusted. That is if your parking brake cable is still connected. When was the last time the rear brakes were done. you may want to pull the tires and drum off and make sure that the adjuster isn't frozen. that would prevent the rears from autoadjustng. Some cars/trucks rely on the parking brake to be set periodically to adjust the rear brakes. My 97 ranger was that way.
just from owning a few muscle cars and now my bronco i've learned that the type of rims you run plays a big part in getting air to the brakes and rotors too cool them.Had a firebird with centrelines on it,no holes in the rims.I would kill the rotors in about 4 months.They are get for show or 1/4 mile runs but daily driving would heat them up like crazy.Stock rims on my 80 bronco with the holes still i belive is why i replace my pads every 8 months or so, just not enough air flowing by.All brand new brakes too,so backs are working and set up fine.
