Vin number location on frame
Old Jan 7, 2015 | 10:41 AM
  #31
GrifN's Avatar
GrifN
Originally Posted by ALBUQ F-1
Agree on the potential for MVD wanting to see the frame stampings, but I can't believe that crossmember is the only place it's stamped on a mid-fifty. You'd have to pull the radiator to see that. I thought they were also stamped on the side rail, a little further back than on a 48-52?
I agree -- DMV said the police would need to verify the VIN, and I doubt they're just going to take my word for it.
My VIN (it's theoretically a '53) is further back than the 48-52 (which I think were near the shock mount?). If you drop a plumb line down from the firewall, it would hit pretty much the middle of my VIN. It was probably 6-8" forward of the cab mount, on the passenger side.
I just want to find a way to remove the paint without removing metal. I'd like to know what the VIN says before the police/inspector arrive, and I so desperately want to verify what year I actually have...
Old Jan 7, 2015 | 11:11 AM
  #32
52 Merc's Avatar
52 Merc
You could always dab a bit of chemical paint stripper on the area and let it go to work. That'll take it down to bare metal without hurting anything but paint.
Old Jan 7, 2015 | 11:20 AM
  #33
GrifN's Avatar
GrifN
Very true. I know plenty of people swear by aircraft stripper, which (I hear) can be picked up from AutoZone. The acetone wasn't cutting it, so I need something stronger.
Old Jan 7, 2015 | 11:43 AM
  #34
ALBUQ F-1's Avatar
ALBUQ F-1
Don't use sandpaper, use a scotchbrite pad. Stamping displaces the metal to the sides and up, if you sand it will remove the ridges around each letter/number.
Old Jan 7, 2015 | 11:45 AM
  #35
Tedster9's Avatar
Tedster9
MEK should remove the paint.
Old Jan 7, 2015 | 11:58 AM
  #36
ligito's Avatar
ligito
Ford likes to hide serial numbers.
On the '60's era vans, they even had one stamped under the doghouse.
Just one of many places they put it.
Old Feb 10, 2017 | 12:13 AM
  #37
Timothy R. Wyatt's Avatar
Timothy R. Wyatt
Originally Posted by drquest65
Well guys i found the vin numbers! they were located on te front ross member on the pasenger side right near the radiator thanks for all the help on this one every one!!!maybe someday when i become knowledge i can repay the Favor
Craig.
Would love to see a photo. I have a 54 and I can't find a vin anywhere.
Old Feb 10, 2017 | 08:11 AM
  #38
abe's Avatar
abe
Am I assuming correctly that the inner fender must be off to see the see the numbers on a 53 to 55 truck?
ashlockbrian
58
Mar 31, 2024 09:04 PM
Diesel_Brad
Aug 3, 2020 06:14 PM
Rennat_2006
33
Sep 25, 2019 10:46 AM
Atomices
17
Aug 6, 2017 10:34 PM
nathankershaw
Jan 4, 2017 05:31 PM
