Forged Steel Crank
Old 04-23-2004, 08:35 AM
46 Y-block's Avatar
46 Y-block
46 Y-block is offline
Forged Steel Crank
I have heard it often that forged steel cranks are stronger, but aren't the other cranks, I guess they would be cast, adequately strong? Is the main advantage to the forged crank that they can be offset ground for longer stroke?
One more question, was the forged crank used in 63 pickups? I am trying to buy a core 292 not far from me that is in a 1963 3/4 ton 4WD.
I also read that the later model trucks equipped with Y's, had stronger blocks that could withstand larger overbores.
True?
Mike in Southern Oregon
Old 04-23-2004, 09:40 AM
286merc's Avatar
286merc
286merc is offline
The forged crank was standard in 61-4 F-600's and optional in others. I have found them in F/C-500's. The VIN tag plate will say HD if the option was installed.
That crank is stronger but heavier than the cast version. I see no particular advantage in using in a truck unless you are really going to run it hard such as an overloaded dump.
I have one in my 54 F-350 but that was only 'cuz the donor engine came from a 64 F-600.
The Altered roadster Im building will be running a reground 312 crank in a 292 block, I see no need for the forged version.
C-700
08-25-2014 12:34 PM
jacks61ford
1961 - 1963 F100 Unibody
02-19-2014 11:50 PM
turbogus
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
11-03-2010 02:34 PM
mustangman
11-22-2004 09:41 PM
turbogus
22
02-01-2004 05:20 PM
Quick Reply: Forged Steel Crank
