Can someone post the International part #'s for the fuel filter and air filter ? I have a '02 F-250 PSD.....Also I just did a oil service and now the truck is idling rough, I checked the oil lvl and got a tad over the line...maybe a quart. Would that cause this?
>Thanks,
I don't know if International makes the air filter for the 2002 psd. The fuel filter number is f4596,
being a qt. over on the oil wouldn't cause the rough idle.
Having the wrong kind of oil, I'am guessing, could because of foaming.
Are you using a heavy duty diesel oil?
hang around someone will be around soon.
Yes, Delo15/40. This was my 4th oil service. 1st ford did, 2nd I used Delo 15/40, 3rd I used Delvac 15/40 and Delo this time again.
Maybe it just had a bad day and felt like missing
Well gseeders,
I went to the International dealer and they could not find a listing for the "F4596" said it did not exist or were they able to cross ref the # I got from Ford, a F81Z number. They said the Fleetguard FF5418 is what everyone else uses on the late mdl powerstrokes and it was $24.73, still cheaper than the $54.41 Ford price. I am going to remove the old one and see if they match....unless someone knows something I don't
>of foaming.
Eric - International Fuel part number is: 1825864c92 - parts man came out, checked the housing, and got the part - all for about $16.
Took me about 15 min to change it.
Eric I bought mine from diesel injection service and the Ford Diesel web site and two from International all used The f4596 #, paid 10.50 to 11.50 ec. I now have plenty. Sorry that your experance wasn't positive. Thay are sold under the fleetguard name as someone else said. Ford sucks on there service parts price. Maybe fleetguard will come out with your air filter soon.
I just picked up a 2000 psd. Had the oil and fuel filters changed where i used to work. They are using ( i believe ) napa filters
fuel filter #95518 and oil filter #92734. Try the numbers at the counter first to make sure they arent changed from year to year.
Also, I've been into diesel for 30 years now and have used shell rotella 15-40 all that time.
good luck with your scooter.
