i oiled mine, both rebuilding books i have say to do that, in fact i went as far as to fill the holes in the bearing journals, can't over do it on oiling a new engine, when you get everything together make sure you prime the whole system, use an old shaft from a distributor and turn it in the direction of your engines firing order, which should be CCW.
On all your bearing surfaces, make sure the contact side between cap and bearing are clean and dry when assembling. Lube only the bearing to journal side. The back side uses friction to prevent slippage. I use a mixture of STP and engine oil(50/50) for build up. Helps hold the lube in place until start up.
Yes. It is designed to keep the crank from flying thru the radiator when the brakes get slamed. It's something you don't think about very often. Imagine needing to stop a 60 pound crank from heading down the road when you slam on the brakes at 50 MPH. The stop and go forces of the truck put pressure on the sides faces of the bearing.
$75! lucky dog, i had to wait almost a whole year to get mine, man was it frustrating, shop had ordered them, then after several months, they said NLA, but they had a set of rebuilt 96 mustang heads for $425.00, then several months later they finally had those done but the price was now $1198.00. i then had another place check, they said it might take several months, and then they said NLA, i then found them on my own. man what a load!
