[updated:LAST EDITED ON 02-Oct-02 AT 00:37 AM (EST)]I am new to submitting even though I have been following you guys for a while. My truck did something that I would consider wierd today. I don't drive it real regularly and It has had very few probs. It had been sitting since Sunday, when I went to start it this afternoon it started just fine. It was about 25 degrees last night so it started good considering. It ran until the glow plugs quit burning and then it was like the key was shut off. The only light that came on was the Battery light saying that it wasn't charging. I tried to restart, It turns over but there is nothing. Pop the hood and found that the Fuse #22 in the control box was blown. It controlls the glow plugs and something on the ignition system. My Question is what would cause it to blow. I replaced the 30 amp fuse and it started right up. Hasn't had any other probs since. What would cause that fuse to blow and is there something else that I need to worry about. Any info is greatly appreciated. Chris
