drain plug behind the belt?
Old Apr 19, 2004 | 09:10 PM
Bribo's Avatar
Bribo
Ok, so I'm a mechanic mental midget...but that's what makes this forum so great for me!
I was crawling around under my rig to drain the fuel filter, and noticed a drain plug directly behind the belt that was wet with what looked like motor oil. What is this drain plug for?
Old Jun 26, 2004 | 03:03 PM
1gary's Avatar
1gary
Can't help with what it is but mine looks like it is leaking. Hope somebody know something.
Old Jun 26, 2004 | 04:07 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to FTE a Family Ford site..........take a moment to read the Guidelines
Then enjoy all FTE offers.....
Old Jun 26, 2004 | 04:36 PM
International Tech's Avatar
International Tech
where exactly is it? You have to fuel lines at each head behind the belt that sounds like what u r describing. Those lines have crush washers and sounds like what u r describing but need more info. Thanks
Old Jun 26, 2004 | 08:49 PM
IB Tim's Avatar
IB Tim
Can you post a small picture
SBV45's Avatar
SBV45
I don't have any belts around the fuel filter fuel/water separator. Maybe you could give me some more clues as to where this drain plug and belt are located.
Old Jun 26, 2004 | 09:22 PM
bedwards's Avatar
bedwards
I bet its the cap on your low oil pressure regulator. They have an o ring that sometimes leaks. Underneath the front of the engine, just behind the fanbelt. It takes a hex key to remove.
BE
Old Jun 27, 2004 | 11:05 AM
1gary's Avatar
1gary
Bedwards nailed this one. I appears that you need a large hex key.....Maybe I'll let the dealer take a shot at it as I don't have any tool to fit it. Many Thanks
