Offroad & 4x4
Cages
Old Apr 19, 2004 | 08:34 PM
Idiomaticman's Avatar
Idiomaticman
Cages
ok boys, what you all use to make/create/bend/weld/etc. your cages/truggies/buggies with?
i found a cheap bender from harbor freight. i love that place.. ....
now, what did you use for materials? for a welder? notcher? what did you pay per foot for material? what size tubing did you use?
i have my cage designed, but i need to know to do.
help me out. post up your pics, ill post up my design.
what you think?
Idio
Old Apr 19, 2004 | 09:27 PM
fishmanndotcom's Avatar
fishmanndotcom
i know a Pro 105 hydro bender is a damn good deal for the money and the quality. and for cages I would highly suggest using a TIG welder but it all starts to get real expensive.
i haven't gotten real into depth with this yet but that is what I have heard from experienced builders.
i dunno if you have seen this but you will prolly find all your answers HERE
-jason-
Old Apr 19, 2004 | 09:43 PM
proeliator's Avatar
proeliator
Sure, a tig would be great but no need to go to that expense. A mig would be fine. Take Fishy's advice and spend more money on a bender if you can. It pays off with less headaches. Use DOM and no need to go ultra-crazy on your cage, as is depicted in your drawing. I know allot of the guys on Pirate go crazy with their cages as it seems to be the rage now, but it really isn't neccesary. Simple works.
Old Apr 19, 2004 | 09:59 PM
hoxiii's Avatar
hoxiii
here's some things to consider with a bender:
1.what would it cost to buy the bender and notcher
2.how long would it take you to bend it all
3.how much material are you going to be wasting testing the bender out to be sure your bends are correct
4. how many tube projects are you actually going to build
I considered these and then went to a chassis shop and talked to a guy there. If i were to buy the tubing for my cage, give them the specs to bend it to, and let the pros bend it and notch it, it actually wound up being alot cheaper than going through the hassle of buying and learning a bender. I then get all the pieces and weld them up in the truck.
Just something to think about.
Justin
Old Apr 19, 2004 | 10:57 PM
ivanribic's Avatar
ivanribic
But Idio, there are no bends on the cage you designed . . . it's all sticks and angles . . . chopsaw and wirefeed. I agree, it's a cool looking design but think it's a little overkill unless you're entering a rollover contest. Seriously though, a bender would make things easy but probably won't be necessary for what you're doing.
Old Apr 19, 2004 | 10:59 PM
proeliator's Avatar
proeliator
I'm sure Ivan forgot to mention that you'll need to have your cage chromed once its built
Old Apr 19, 2004 | 11:09 PM
ivanribic's Avatar
ivanribic
Hey, I know a shop if you want to. . Speaking of which, this is way off subject but since Pro brought it up: I just got my new bumper (used). It's got a winch roller and all that in it but it's a scuffed up white right now which will look like crap on my truck. Don't think I'd like the look of black either so unless I can figure out a good color to powder coat it I'll be off to have it dipped . . . perhaps some before and after pics are in order.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWN%3AIT
Old Apr 19, 2004 | 11:11 PM
proeliator's Avatar
proeliator
Powder coat it hot pink so you can be "that guy".
Old Apr 19, 2004 | 11:13 PM
ivanribic's Avatar
ivanribic
Waaaaaiiiiit a minute, you think that's why Idio used so many bright colors? Is that the color scheme he plans to use on his cage? Crap, and I thought I had bad tastes in colors.
Old Apr 19, 2004 | 11:20 PM
proeliator's Avatar
proeliator
Naaa, I think he was planning on wrapping his cage with those neon rope lights
I have to confess, I've given serious thought to painting Superbeast lime cuda green.
I'll probably stick with the olive drab or flat black though.
Old Apr 19, 2004 | 11:26 PM
ivanribic's Avatar
ivanribic
Olive drab would look cool as hell on that truck . . . good old military surplus and then when you scrape it up you can just spray some more on there. Too many people are already running around with flat black, always looks to me like they never got past the primer stage.
Can we chrome your roll bar?
Old Apr 19, 2004 | 11:31 PM
proeliator's Avatar
proeliator
Over my dead body
Yea, I've been bouncing between olive drab with white stars on the doors and military markings (with little siliouttes of jeeps and ricers on the fenders to indicate "kills").
OR
Just flat black with a white Punisher skull on either door. I've had many, many vehicles over the years that I kept flat black and kinda have a thing for it. Still not sure which way to go...
edit: If I could ever figure out how to post a poll I'd throw one up
Old Apr 19, 2004 | 11:34 PM
95-F-350-4x4's Avatar
95-F-350-4x4
Why do new roll cages look like jungle gyms? I mean jeez all those tubes of metal have to be heavy as hell right?
Old Apr 19, 2004 | 11:42 PM
proeliator's Avatar
proeliator
Mostly because guys get carried away. I've seen way too many cages that had a ridiculous amount of tubing. Better to overbuild than under but enoughs enough.
Cool avatar '95. That was actually my original avater at FTE, but when Ken shrunk the avatar size a couple years back I was never able to figure out how to crop it to make it work, so had to change it for the current one. Anyways, made me nostalgic...I loved that avatar, good choice
Old Apr 19, 2004 | 11:50 PM
hoxiii's Avatar
hoxiii
All this chrome talk is making me sick
After i rebuild my 205 my next step is actually going to be dechroming Bumper'll be gone, wheel arch trim, even have a set of chrome 15x8's that are getting sandblasted and painted white. even considering painting the grill. As you can tell i really miss my '67
AS for the specific cage design, it is a bit overkill. a hoop out front and one right behind your seat is really all you need. then run a couple roof links with a diagonal and a door bar and call it good. Just be sure to use big enough tubing.
Justin
