door ajar?
Old Apr 19, 2004 | 06:15 PM
Sugarlips's Avatar
Sugarlips
door ajar?
umm, i have a 99 ranger, my door ajar light came on today while driving and will not go off! and yes the doors were closed tight!! came home, turned truck off,shut my drivers side door and the key was chiming! whack huh? could this be a fuse, or a switch??
Old Apr 19, 2004 | 06:19 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
This door ajar light a common problem and usually an easy fix. Yes, it's the switch; most likely there is some corrosion causing it to stick. At the top of this forum there is a sticky called technical info. Go in there, look under misc and you will find info on how to correct this.
Old Apr 19, 2004 | 09:25 PM
mcryder1950's Avatar
mcryder1950
door ajar possible fix
My 98 ranger had the same problem. I took it to my local FOrd dealer & he told me to spray WD40 (what else?) inside the mechanism. I did, & the problem has not happened since
Old Apr 20, 2004 | 11:09 AM
Donald Rohret's Avatar
Donald Rohret
Good advice. WD-40 is the common fix for your problem and works in most cases. After you spray some in the door latch, work the door several times and hopefully you will have cured your problem.
Old Apr 23, 2004 | 06:01 PM
jlabrecquevt's Avatar
jlabrecquevt
Thankyou for the great tip on how to remidy the "Door Ajar" light on my 03' ranger.....a few squirts of WD-40 and it cured it....Kind of sneaky of Ford to hide the switch inside the door... where you cant see it...but anyway thanks again!!
Old Apr 27, 2004 | 11:38 AM
Sugarlips's Avatar
Sugarlips
thanx u guys for the heads up.. WD40 seems to have worked.. now if u can just tell me what WD stands for you'd b doin sumthing j/k!
Old Apr 27, 2004 | 11:57 AM
wire4money's Avatar
wire4money
water displacement
Old Apr 27, 2004 | 12:10 PM
99 ranger bob's Avatar
99 ranger bob
as copied from the press release section of the WD 40 websiteas to how WD40 got its name and what it stands for:
WD-40, one of America’s – actually the world’s – favorite products, originated in the space age. What was created in a small lab in San Diego for use on the Atlas missile is now in eight out of 10 U.S. households, sold in 160 countries and used by millions of people every day.
In 1953, three technicians at what was then known as Rocket Chemical Company set out to create a line of rust-preventive solvents and degreasers to protect missile parts from corrosion. It took them 40 attempts to finalize the formula, but it worked. WD-40, which stands for Water Displacement perfected on the 40th try, was born.
The product, used by several aerospace contractors, was seen as a magic elixir worthy of bootlegging. Workers smuggled it out of the factory and discovered new uses, such as protecting tools, lubricating machinery and loosening nuts and bolts. Word traveled, and people quickly realized WD-40 truly was the world’s first multi-purpose problem solver, giving any cleaning agent, lubricant, penetrant, solvent or rust inhibitor a run for its money.
Since then, legions of fans have come to rely on the product in the familiar blue and yellow can. They use it to clean car bumpers of grease, grime and bugs, remove crayon marks and prevent rust on gardening equipment and outdoor furniture.
NOW i can tell the old lady i did something today
Old May 4, 2004 | 08:54 PM
Sugarlips's Avatar
Sugarlips
gee rangerbob you really did your research
