Been running my own survey. And a ?
There are a lot of 03 and 04 PSDs running around here in Houston. I have made it a point of asking everyone that I can about how theirs has treated them. Be it at a stop light, or while getting "gas", or when ever the opportunity presents itself. I guess so far I have spoken to between 15 and 20 owners, of which a little more than half have been 03 owners. Three 03 owners have not been happy since with the infamous May, I believe, flash. Prior to it they had no issues, but things have not been right since. Issues with gas mileage, loss of power and smoking are the problems they site. But prior to the flash everything was great. Ford really dropped the ball with that one, One of those 03 owners took his in for a loose boost hose and was really ****ed that they flashed his truck while it was there. Of the 04 owners one had a rear main seal leak, but it was fixed about 3 months ago and all is well. None of the others have had any problems. You can include me in that group. Not a scientific survey by any means, but it does show me that most PSD's seem to be just fine.
Now a question. What is meant by "Tip In"? Is that when you first give it throttle from idle? I do notice a definite change in sound right when you give it throttle.
Originally Posted by jeb
So in your survey, 20% of the owners (3 of 15) are unhappy with their trucks. Not a good percentage, if you ask me.
I see your point Fred, but the problems have encompassed far greater things than software changes. Faulty injectors, turbo problems, and fuel leaks into the oil pan are several of the common problems.
I think the percentage of 6.0's with problems is probably less in reality than someone would think reading this website though (I'M NOT SAYING THERE AREN'T PROBLEMS). The main reason is that people who have problems are likely nowadays to search the internet and they stumble across a website like this and seek answers. If you'll notice a lot of the new members are people posting about a problem they're having.
My conclusion/observations are that there are indeed more problems than software issues but the % of engines with problems is probably lower than you would guess by reading the 6.0 PSD forum.
![Question](images/icons/icon5.gif)
Also was wondering how many dealers would inform their customers of a rear seal leak if they discover it while doing other work since the success rate of fixing this problem seems to be very low.
Surveys are nice for buyers and those who are having problems
I have a 03 6.0 F350 SuperDuty Crewcab. Build date is 05/03. Bought in July of 03. Our problems didn't start until 26,000 miles on the truck. First and foremost, I love my truck, have had them and will continue to buy them. I have had all 8 injectors replaced and three of them twice totalling eleven in all replaced. The turbo once but is in shop now for another turbo they believe but will check it out Monday to see if it might be another injector gone bad, want to check it on cold start. We have had the egr valve, map sensor, crank shaft sensor, low pressure sensor, turbo blower hose, and a host of other things replaced on our truck, some of these one, two and three different times. Our truck stays in the shop more these days than when first purchased. Our mecanic told us today that ford rep told him it had to be the inadequate fuel being used. DUH! Where do you buy fuel if it's not at a truck stop. Fuel that moves and is constantly being replaced seems to be a good choice I would think. We are also getting poor fuel mileage, very poor, about 8.5 pulling a trailer. We hear people talking about flash but have never heard this before.
Wow,,,Maryfrank,, thats alot of stuff replaced on your truck !! I would be kinda upset I think,,,,
I know from past experience,
, I wont bring my truck in unless it's absolutly nessecary for warranty work,,,,On my 95' PSD,, tech said it was skipping,,,NOT,,after he worked on it,,,it was much worse,,no power,,dent in my fender,, heat wrap ( foil on firewall ), around AC,,all crumpled and messed up,,the thing ran good before it went in,,but went in for a blown vacum pump, and mis-aligned belt tensioner, It seems like they did,nt really know that much about the PSD at that time,,I would think by now they would have a clue,,I hope things work out for you.
Later,,,,,,,,Mark
![Argue](images/smilies2/argue.gif)
![Cussing](images/smilies2/cussing.gif)
Later,,,,,,,,Mark
