Been running my own survey. And a ?
The turbo once but is in shop now for another turbo they believe but will check it out Monday to see if it might be another injector gone bad, want to check it on cold start. We have had the egr valve, map sensor, crank shaft sensor, low pressure sensor, turbo blower hose, and a host of other things replaced on our truck, some of these one, two and three different times. Our truck stays in the shop more these days than when first purchased. Our mecanic told us today that ford rep told him it had to be the inadequate fuel being used. DUH!
Originally Posted by johnsdiesel
I see your point Fred, but the problems have encompassed far greater things than software changes. Faulty injectors, turbo problems, and fuel leaks into the oil pan are several of the common problems.
I think the percentage of 6.0's with problems is probably less in reality than someone would think reading this website though (I'M NOT SAYING THERE AREN'T PROBLEMS). The main reason is that people who have problems are likely nowadays to search the internet and they stumble across a website like this and seek answers. If you'll notice a lot of the new members are people posting about a problem they're having.
My conclusion/observations are that there are indeed more problems than software issues but the % of engines with problems is probably lower than you would guess by reading the 6.0 PSD forum.
My survey percentage is as valad as any and it is 100% satisfied owners.
Tampa250
03-26-2015 01:44 PM
