2.3L timing/Knocking problems
Old Apr 18, 2004 | 07:57 PM
fmarino's Avatar
fmarino
Exclamation 2.3L timing/Knocking problems
Hi there, I replaced the timing belt on my 94 ranger. I noticed that the old one was a tooth off! In any case, I put the new one on correctly. But now, the engine is knocking a lot when driving it! One thing I noticed is that the base timing is OK at 10 BTC, but as soon as I plug the SPOUT, the timing jumps to 20 BTC and when I rev it up, the timing goes way past the scale to about 40 BTC, is that normal? Another thing, Can I try to decarbon this engine? I read the procedure for a 4L engine, can I try that on this one? Thanks a bunch.
Old Apr 18, 2004 | 08:37 PM
Ken00's Avatar
Ken00
Its normal for the timing to advance when the spout is reconnected, and those numbers seem OK. You can use the same procedure as the 4.0. Are you sure that it was off by one tooth?
Old Apr 18, 2004 | 08:45 PM
fmarino's Avatar
fmarino
Smile Knocking Problems
Yes, the haynes manual shows the crankshaft keyway at 12 o'clock, but in my engine it was at about 1 o'clock. The funny thing is that the engine run like that! I'm going to try decarbonning the engine tomorrow, I hope that gets rid of the knocking. Thank you for your help.
Old Apr 18, 2004 | 08:51 PM
Ken00's Avatar
Ken00
Let us know how things go. Does anyone have any comments on the correct position?
justanother1
Mar 30, 2007 11:05 AM
lattices2
1978 - 1996 Big Bronco
Oct 4, 2005 01:17 PM
lattices2
Aug 26, 2005 04:01 AM
88blkranger
Aug 6, 2004 10:07 AM
Harleymw
May 14, 2004 09:54 PM
