Oil Filter ?
Old Oct 27, 2002 | 09:05 PM
SatZ28's Avatar
SatZ28
Post Oil Filter ?
I changed my oil today for the 1st time. The warning tag on the oil pan indicated to tighten the filter 1 1/2 turns. Is this after hand tightening or after the filter gasket is in contact with the filter housing? I tried to turn the filter an additional 1 1/2 turns after hand tightening, but was only able to turn the filter an additional 3/4's turn using a wrench.
The normal procedure on my cars is to hand tighten, then a 1/2 turn more without the use of a filter wrench.
What is correct?
Old Oct 27, 2002 | 09:34 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Oil Filter ?
I've always used hand tight plus 1/2 also. Works fine on the PSD.
Old Oct 28, 2002 | 09:19 AM
gseeders's Avatar
gseeders
Oil Filter ?
>a wrench.
how do you tighten by hand then get another 1/2 turn without a wrench?
>What is correct?
lots of opinion here at this site but it really your truck and your experience that counts.
I have all my life used hand tighten on every thing I own as well as on customers cars when I worked in shops and never had a problem. This includes o-ring,flat and bevel type seals. I also believe in oem filters.
My step son believes to tighten every thing till it won't budge or to failer! I can't get him to change!
I can't tell when the seal actualy comes in contact with the seal surface, so again just hand tighten with one hand is all I do.
over and out
gseeders
Old Oct 28, 2002 | 11:19 AM
REDRIG's Avatar
REDRIG
Oil Filter ?
magog77
Oil & Lubrication
31
Oct 6, 2011 10:19 AM
matt1751
Jan 2, 2011 06:56 AM
bimmertrek
Modular V10 (6.8l)
Sep 19, 2010 10:43 AM
00 Nav
Feb 8, 2009 01:06 PM
Fordman_Evs
20
Jun 8, 2006 07:22 PM
