Oil Filter Fit
Old Jan 1, 2011 | 06:47 PM
matt1751's Avatar
matt1751
Oil Filter Fit
Hi, Just a question for you V10 owners. I picked up a 03 Ex last month with the V10. I was changing the oil and filter today. It had a ac delco filter on it very tight, I replaced it with a Motorcraft, My question is that there seems to be about a 1/8" gap or so from the bottom of the filter and the housing. is this normal or should it fit flush? I didn't notice the fit of the one I took off. I Started the truck and didn't notice any leaks. All my other vehicles I've had the filters always fitted flush and usually were able to hand tighten them and then just a 1/4 to 1/2 turn with filter wrench. . Any info would be appreciated.
Old Jan 1, 2011 | 07:44 PM
jh818's Avatar
jh818
As long as the rubber seal touches the mount and you get no metal to metal rubbing, then it should be good. The size of the gap depends on how thick/tall the rubber seal is anyway.
Old Jan 1, 2011 | 10:12 PM
matt1751's Avatar
matt1751
thanks for the reply, The rubber seal is touching the mount, This was just the first oil filter I've even did that had a gap, all the other vehicles I've owned they alway were flush, Maybe this filter just has a larger seal on it. Thanks again for the reply
Old Jan 2, 2011 | 06:56 AM
tdappleman's Avatar
tdappleman
You shouldn't tighten the oil filter with a wrench - let the gasket come into contact with the base plate and then hand tighten. I've got a similar spacing with mine using the FL820s filter - so you shouldn't have anything to worry about.
BryanStein
Sep 23, 2015 10:54 PM
fordman19762003
2009 - 2014 F150
Sep 29, 2013 08:58 PM
hink10
Sep 30, 2012 11:34 AM
ssharber
Mar 29, 2010 11:39 AM
69ford99
2004 - 2008 F150
Sep 5, 2009 09:47 PM
