Fool the computer & change timing
Old Apr 17, 2004 | 07:06 PM
fordberg's Avatar
fordberg
Years ago I did this and wanted to pass it on in case it helps someone.
On my 85 E-150 6 cylinder I put a variable resistor in line with the temp sender and remoted it into the cab. I found that the computer reads the temp sender and adjusts the timing depending on the engine temp. By adjusting the resistor I could fool the computer into thinking the engine was cold and it then removed some of the advance from the timing. I used this when pulling hills so I didn't get so much nocking from cheap gas. Goo luck.
Old Apr 17, 2004 | 08:53 PM
stevef100s's Avatar
stevef100s
Hey, that's a great idea. That's even better then installing a cooler thermostat. They do the same thing, but your idea keeps the engine in the proper temp range. I'll remember that one. Where did you get the variable resistor. Is it like a rheostat?
Old Apr 17, 2004 | 09:10 PM
fordberg's Avatar
fordberg
In electronics circles it would be called a potentiometer(POT). Like the old radios. Old being 5 years ago. I panel mounted it and put a **** on it. Can't remember the resistance. 50k I think. I remember trying it in parallel and in series. I think I liked it best in series. It also changed the idle by a few hundred RPM when I turned the POT. Be careful, I also remember that when you change the resistance that the computer changes the fuel mixture. It might mess up your plugs.
Old Apr 17, 2004 | 11:34 PM
stevef100s's Avatar
stevef100s
I believe that a POT wired as you described, functions as a rheostat. Potentiometers find their most sophisticated application as voltage dividers, where shaft position determines a specific voltage division ratio. However, there are applications where we don't necessarily need a variable voltage divider, but merely a variable resistor: a two-terminal device. Technically, a variable resistor is known as a rheostat, but potentiometers can be made to function as rheostats quite easily.
Old Apr 18, 2004 | 03:45 AM
fordberg's Avatar
fordberg
I usually reserve the word rheostat for a device that needs to handle a large load or lots of power. Like in the old trucks, they used rheostats to control the heater motors. On a three lead POT use one end and the wiper in the middle to get an adjustable resistor.
LSAtexan4x4
Jan 9, 2012 01:03 PM
DKW 86
Apr 21, 2011 08:37 PM
Old_Crow
Feb 13, 2010 09:56 PM
RedneckF-150
28
Dec 29, 2005 10:35 AM
Ford Truck Racer
Dec 19, 2005 05:56 PM
