Antifreeze smell
Old Oct 31, 2002 | 09:50 AM
Yellardawg's Avatar
Yellardawg
Antifreeze smell
last 2 days I have taken my kid to school and when I got back to the farm, I noticed an antifreeze smell around the front end. It doesn't appear I am losing any and there isn't a spot under the truck. waterpump looks good and sealed.
Any Ideas?
YD
Old Oct 31, 2002 | 10:48 AM
pbrassey's Avatar
pbrassey
Antifreeze smell
Is your defroster working a little less well? My truck is smelling of antifreeze and fogging up the windows. I'm changing the heater core this weekend.
Paul Brassey
1986 F-350 XLT Crew Cab 6.9L
Old Oct 31, 2002 | 01:16 PM
Yellardawg's Avatar
Yellardawg
Antifreeze smell
no, the defroster is workin' fine. Only notice the smell as you walk around the front of the truck. Could the cap be venting off pressure? could it have something to do with the overflow tube? I have yet to see any on the ground and doesn't seem like the level has changed.
Yd
Old Oct 31, 2002 | 07:49 PM
gseeders's Avatar
gseeders
Antifreeze smell
any you smell antifreeze you'll have a leak. It is leaking somewhere.
over and out
gseeders
Old Oct 31, 2002 | 08:41 PM
c_nate's Avatar
c_nate
Antifreeze smell
if you got a small leak. you might only smell it and not see it. Especial if it is the radiator. they leak when they are hot, the coolant evaporates before dripping on the ground, so you just smell it, can't see it. is your coolant level in the over flow tank going down. I'd just wait till it leaks more, then your sure to tell then
Old Oct 31, 2002 | 09:42 PM
Yellardawg's Avatar
Yellardawg
Antifreeze smell
Ok, I did find 3 drips this evening and they evaporated almost instantly. What do you guys suggest? Should I take it somewhere to be checked out, this is a very small leak, without the smell I wouldn't have noticed. Or would you use one of the "Snake Oil" remedies like Bars leaks????
Thanks
YD
Old Oct 31, 2002 | 11:23 PM
c_nate's Avatar
c_nate
Antifreeze smell
stay away from those " snake oil" remedies. they clog up your cooling system. I tore apart a gasser that had a coolant leak at freeze out plug, prev owners tried to stop it with leak stop. whole back end of engine (170 cdi 6) was clogged with "gunk" ( for lack of better term) I don't know what truck you got, but radiators are expensive. check all your hoses, etc and be sure what it is.
I heard of folks having good luck with those dye tracing kits. what you do is put a UV dye in the coolant. then you search for the leaks with a UV light. heard that it works well from friends, never tried my self.
best of luck,
Nate
Old Nov 3, 2002 | 07:58 AM
FortyFords's Avatar
FortyFords
Antifreeze smell
Chk the around your end pieces on your radiator,with aluminum cores and plastic ends there are rubber gaskets between them which are pinched to seal by bending tabs. On cold mornings plastic and aluminum contract so the rubber gasket leaks !
Rich
Old Nov 3, 2002 | 08:18 AM
Original Mr Plow's Avatar
Original Mr Plow
Antifreeze smell
I'm only mentioning the experience I had becuase I wouldn't want it to happen to you or anyone else. For about two weeks when I started up in the morning after a couple of minutes I would then hear the warmed up coolant start to flow into the heater core. I was ignorant to what the problem. One day, while driving down the hiway, the thermostat seized up and overheater the engine, blew a head gasket and to out the engine, smelled like antifreeze all over the place. All over a 2 dollar part. This was in my car not my PSD. Does anyone know if this would be of concern in the PSD? I only mention because I believe all internal combustion engines must run head gaskets to allow coolant flow around the heads. Some discussion might help me understand better. I've learned alot from the posts I've read on this board. Alot more than all my years trying to get info out of the dealer!!!
Old Nov 3, 2002 | 11:31 AM
bilder12's Avatar
bilder12
Antifreeze smell
coatit
2009 - 2014 F150
Jul 11, 2013 10:27 AM
Hardcase_Ford
Bronco II
Nov 11, 2008 10:07 AM
ValkyrieVixen
1983 - 2012 Ranger & B-Series
Nov 2, 2007 09:41 AM
Offroadingman
Mar 12, 2005 07:03 PM
Ed the outdoorman
Oct 28, 2004 09:41 AM
