Dash Dimmer wire?
Old Apr 16, 2004 | 11:23 PM
DanMartin's Avatar
DanMartin
Dash Dimmer wire?
Hey all,
I'm installing some aftermarket gauges, and would like to wire the lights in them to the dash dimmer switch. I've tried to decypher the wiring diagram in my Haynes manual, but for my year (1986) the wire color for the dimmer is not listed (has it for 85, but it looks like 85 had a slightly different dash circuit board connector).
Anyways...does anyone know which wire coming off the dimmer switch controls the voltage to the dash lights? I don't want to crack out the volt meter if I don't have to....there's a lot of wires to check.
Oh..btw, this is an XL with tach.
Thanks all!
Dan Martin
1986 F350 1-Ton Dually Crew cab, 460, C6, 4.10:1 gears
Old Apr 17, 2004 | 12:16 AM
82F100SWB's Avatar
82F100SWB
Light blue with red tracer is the dash lighting power source. Lots of 'em behind the dash, just pull teh cap off and look around where you have your guages situated, I'm sure there'll be one close by to tap into
Old Apr 17, 2004 | 01:00 AM
DanMartin's Avatar
DanMartin
Thanks man...looks like it's the same as the 85 then.
Dan
Old Apr 17, 2004 | 06:58 AM
bremen242's Avatar
bremen242
I always pull off the headlight switch and tap it there. for some reason I think it is white with black or blue, but 82 probably has it right.. I'll have to look in my manual..
Old Apr 17, 2004 | 11:47 AM
Beast12's Avatar
Beast12
82F100 is right. It is a light blue wire with a red stripe on it. You can also use the one from your radio if you wanted.
-Matt
Old Apr 17, 2004 | 12:51 PM
DanMartin's Avatar
DanMartin
I looked but could not find the radio wire...lost in the maze behind the dash I'm sure.
I'll find the blue/red wire...thanks all!
Dan
Old Apr 17, 2004 | 07:52 PM
nickmobile67's Avatar
nickmobile67
I'd check to see which fuse is for dash lights. Then I'd get some fuse taps and just come off that. you should be able to tell from your books which fuse is for the lights, but a test light will be a good check. Also make sure you tap off the side after the fuse, not before, so the fuse will protect your new circuit.
Old Apr 17, 2004 | 10:57 PM
DanMartin's Avatar
DanMartin
Actually I found an easy way once I got the right wire. If you take off the dash plate, there is a light right above the light/wiper switch that illuminates them. If you take out the screw that holds the metal bracket that the light is held by, and pull it out...suprise! It's the light blue/red wire!!! Tapped off of that, and put everything back together and it's working great! The gauges work perfectly and light up and dim with the other lights.
Thanks for all the help guys!
Dan
e30rik
Dec 26, 2016 12:23 PM
Jayrod00
2004 - 2008 F150
Jan 4, 2016 08:36 PM
duphofff
Sep 6, 2015 05:43 AM
Ryan Felshaw
1997 - 2003 F150
Jun 16, 2015 01:42 AM
kenpep2
Electrical Systems/Wiring
Sep 28, 2003 07:37 PM
