Installing Speakers
Old Apr 16, 2004 | 09:58 PM
ScrewBuddy's Avatar
ScrewBuddy
Question Installing Speakers
Thanks to some earlier posts from some helpful folks, I was able to install new speakers in the front doors of my Super Crew. Emboldened by my success, I turned to the rear doors and speakers.
But the rear door panel over the speakers is much harder to remove than the front. I cannot get my knife, screw driver or other prying tool into the seam to pry open the panel.
Is there a trick to it? Am I just being too timid? Any help is appreciated.
Thanks,
Buddy
Old Apr 17, 2004 | 03:24 PM
fuzzola's Avatar
fuzzola
The plastic panels on the back doors do not come off like the ones on the front doors. You have to remove the entire door panels by removing the bolts on the bottom (2) and behind the inner door pull (2). There are also a few clips to release the panel by pulling out and up. Just feel around. You'll find them. It's not too bad.
Old Apr 17, 2004 | 04:30 PM
ScrewBuddy's Avatar
ScrewBuddy
Found them. Thanks a lot, Fuzzola.
I knew what I was doing didn't seem right.
Old Sep 29, 2004 | 09:17 PM
cccww's Avatar
cccww
2 more screws are in the back on the crews.There is a 10mm head screw behind the pad that has the window switch.The pad just pops up from the front and out.
There is another small screw behind the vertical trim. The trim pulls straight out.
Just replaced the stock speakers and yes they are junk with some kenwood kfc-688c.Boy did that bring that audiophile to life.
Old Sep 29, 2004 | 09:27 PM
snowman7877's Avatar
snowman7877
Is anyone running amps for the speakers? Or does the head unit push enough power for them? Thanks in advance.
Old Sep 29, 2004 | 09:38 PM
cccww's Avatar
cccww
You may need one with some high end MBs or JLs.The hu is fine for pushing the kenwoods I installed.All I want now is mp3
Old Sep 30, 2004 | 11:39 AM
mike8150's Avatar
mike8150
Talking Amp
I installed a 300 watt 4 channel amp and they sound way better. i also put in a 10'' inch subwoofer. sounds great.
jeremiah77
Feb 7, 2015 09:36 PM
dualwheels66
Dec 28, 2011 09:09 PM
fyrbolt
Feb 7, 2005 07:22 PM
James N. Gowan
1978 - 1996 Big Bronco
Apr 12, 2004 11:35 PM
bail5067
May 13, 2001 09:38 PM
