Transmission bangs going into reverse!!
Old Apr 16, 2004 | 01:10 PM
78greenmachine's Avatar
78greenmachine
I have a 1978 F150, and when I put it into reverse there is a pretty good bang. Does anyone know about what I should expect to pay for a rebuilt or new transmission all together?? Or is there anything I can check myself before taking it in? Thanks.........
Old Apr 16, 2004 | 01:39 PM
jpb222's Avatar
jpb222
Is your truck an auto or manual?
It might be that your rear end or dirveshaft is worn, I'd check those for play first.
Old Apr 16, 2004 | 01:48 PM
78greenmachine
IT is an automatic.......Thanks for the info i will check and see what kind of play I have down there.............
Old Apr 16, 2004 | 07:55 PM
rebocardo's Avatar
rebocardo
I would check the driveshaft UJs, especially the one at the rear. If the straps are loose, it will bang when going into reverse. Depending on your shaft, there might be a rubber bushing gone on the slip joint of the shaft that allows the driveshaft assembly to wobble. Might be as simple as a transmission mount. Cheapest thing is to check all the rubber in the truck including radius arm bushings.
Sometimes if the radius arm bushings are gone, it feels like the transmission is slamming when the radius arm hits the bracket because the bushing is worn on the bottom.
As for price of a rebuilt C-6, $800-$1000, depending on quality and warranty.
Old Apr 17, 2004 | 06:50 PM
TNTsF-250's Avatar
TNTsF-250
You might try to remove your drive shaft and put about a small amount of grease (1once)in the yoke and put the dr. shaft back in, it worked for a F-100 , and then your diff.pinion preload may be loose. good luck.and what the other members said.
Old Apr 18, 2004 | 02:38 PM
ScottInTexas's Avatar
ScottInTexas
Give me coffee - Or beer!
Mine too! 1984 F-150, 351W, C6 xmission. I'm gonna follow your progress closely so please post results of what you do.
Old Apr 21, 2004 | 12:24 PM
78greenmachine
I will post my results as soon as I get time to do the work. Thanks .........
RA31925
31
Nov 18, 2016 04:43 PM
CampSpringsJohn
20
Oct 24, 2016 03:31 PM
Dam pile
51
Apr 10, 2016 01:02 PM
schmeck
2004 - 2008 F150
Jun 25, 2015 05:53 PM
Rockyroger
16
Jun 4, 2015 04:06 PM
