Replacing hubs
Old May 1, 2004 | 04:18 PM
BBBxcursion's Avatar
BBBxcursion
No problem
Old Mar 11, 2006 | 12:17 PM
GeneX's Avatar
GeneX
Question Replacing hubs on 2000 Excursion
BBBxcursion
NAPA tried to sell me a conversion kit with the Warn Hubs? Do I need it and
do I need to block off or disconnect the vacuam lines?
Thanks GeneX
Old Mar 11, 2006 | 01:19 PM
BFR250SD's Avatar
BFR250SD
You don't need a conversion kit. The conversion kit is for vehicles that had a "full-time" transfer case. As long as your front axle is the same D60 as on the SD's, they are 100% the same.
Here is a link to the write up I did for the hubs. It's as simple as it gets. It's a 1.4 meg Word document.
http://webpages.charter.net/rsilvano/Documents/Super%20Duty%20Automatic%20to%20Manual%20Hub%20Con version.doc
Old Mar 11, 2006 | 02:16 PM
aklim's Avatar
aklim
I happened to score a couple of hubs that worked. I tried the Warn hubs when one of mine failed. They worked too but the problem is that you end up having to step out of the cab to switch them. The ESOF will enage the transfer case but if you are stuck in snow, you feel like going out and engaging both sides? I didn't so I went back to the Ford hubs.
dhag911
Dec 12, 2013 03:00 AM
kipdog
Modular V10 (6.8l)
Dec 16, 2010 02:08 PM
BII Plow Truck
Bronco II
Dec 22, 2009 07:32 PM
csangster
Jan 21, 2008 08:31 AM
napabob
Mar 14, 2007 04:44 PM
