1978 - 1996 Big Bronco
Bronco Question
Old Apr 15, 2004 | 11:07 PM
parks911's Avatar
parks911
Question Bronco Question
Guys I have a question. A buddy of mine has a early or mid eighties Bronco that has the I6 engine in it. Today I thought I would ask him about it & he said it has a bad engine & he will sell it real cheap if I knew anybody who wanted it.
Well I might want it. The body is rusted badly for being a Minnesota truck but I'm not worried much about that because the primary use would be winter running.
My question is how difficult will it be to put a 302 EFI out of a 1988 F-150 into that beast?
I'm sorry I don't have a model year to tell you for sure but I know it is between 80-86. It is that body stlye.
Old Apr 15, 2004 | 11:09 PM
96Bronco351's Avatar
96Bronco351
Would it bolt up to the transmission?
Old Apr 15, 2004 | 11:11 PM
parks911's Avatar
parks911
I don't know for sure. The engine is coming out of a 2X4 88 F-150.
Old Apr 16, 2004 | 12:29 AM
King Triton's Avatar
King Triton
2 questions,is the bronco 2wd or 4wd and if 2wd why not use engine and trans from the truck?
Old Apr 16, 2004 | 12:33 AM
parks911's Avatar
parks911
The Bronco is 4X4 with a bad I-6 in it. The 302 is out of a 88 F-150 2X4.
I'm sure bellhousing would have to be swapped. I guess my main question is more about the computer systems with the EFI.
Old Apr 16, 2004 | 12:38 AM
King Triton
yes you can do it,the majority of your work will be in removing the wiring harnesses and then putting the efi harness in the bronco,
Old Apr 16, 2004 | 01:15 AM
parks911's Avatar
parks911
OK. That is what I was looking for. I do have the wiring harness off the 88 F-150 & the computer.
When I get back to the shop I will look closer at the truck to determine if it wouldd be worth it or not.
