Headlight Knob '78
Old Apr 14, 2004 | 11:42 PM
tulkas's Avatar
tulkas
Headlight **** '78
I have a question about removing this. I read the previous thread on the same issue, but I was wondering, with the little plastic button on the switch do I push it straight down or it is supposed to slide back? I can get it to slide back but with no amount of force will it go straight down.
Then I have to pull as hard as I can? Is there a specific spot the **** has to be in before I push the button or to pull it out correctly? Do I have to pull until I give myself a hernia? My dash panel is hanging on by this asinine little **** in the corner and I am about ready to snap it off out of anger. They should have made it the same as the rest of the *****.
Old Apr 15, 2004 | 12:02 AM
Torque1st's Avatar
Torque1st
Posting Legend
On all of the switches I have ever taken apart you have to push straight down when the **** is fully extended.
Old Apr 15, 2004 | 12:10 AM
tulkas's Avatar
tulkas
Does it take brute strength or will it pop out easily when I've found the "sweet spot"?
Old Apr 15, 2004 | 12:32 AM
Torque1st's Avatar
Torque1st
Posting Legend
It will pop out easily.
Old Apr 15, 2004 | 12:35 AM
tulkas's Avatar
tulkas
Thanks I'll try to get it.
Old Apr 16, 2004 | 07:09 AM
wckdclwn911's Avatar
wckdclwn911
The button on my headlight switch wont go down until I cut the headlights on
Old Apr 16, 2004 | 10:28 AM
Mil1ion's Avatar
Mil1ion
That's correct.
That's why you disconnect the battery before working on it.
You don't push the button down until the switch is in the *headlights on* position
Old Apr 16, 2004 | 12:39 PM
wckdclwn911
Depends on if ya got a good battery and if you feel like reprogramming your radio!
Old Apr 16, 2004 | 12:46 PM
Torque1st's Avatar
Torque1st
Posting Legend
Or if you want a fire under the dash when the wiring shorts out, or worse yet if you have a ring on your hand... -ALWAYS disconnect the battery.
I saw a picture of a guys hand where a ring had shorted some electrical contacts, burned it down to the bone all the way around, -very nasty.
Old Apr 16, 2004 | 12:53 PM
stepman's Avatar
stepman
Ditto Torque...I have seen more than pictures. You DON'T want it to happen to you.
Old Apr 16, 2004 | 12:56 PM
wckdclwn911
Depends on what youre doing I guess. I havent had to get in depth enough recently to where I was worried about getting into electrical contacts. I have seen what happened to a guy I knew who checked his coil by puttting a screwdriver in it and cranking the motor over at the selenoid.
Shadowrider123
Sep 8, 2014 04:56 PM
berry1234
Mar 22, 2009 08:53 AM
beagledog
Jan 8, 2009 10:47 AM
switchback
1997 - 2003 F150
Sep 22, 2003 02:42 AM
