Sponsored by: Auxito
Air Bag Code 41
Old Apr 14, 2004 | 02:05 PM
SPELLY F150's Avatar
SPELLY F150
Air Bag Code 41
Last night the dang air bag light went on and is now staying on. Can anyone tell me what code 41 means and what a possible fix would be?????
Thanks
Pat
Old Apr 14, 2004 | 06:40 PM
HomerWinzlow's Avatar
HomerWinzlow
Year and model would help. Flash code 41 on a 98 F150 would be a Right hand crash sensor open circuit.
Normal Operation
The voltage at Pin C209-16, Circuit 617 (PK/O), is set by the air bag diagnostic monitor to be slightly less than battery voltage. Circuit 617 (PK/O) is connected to Circuit 624 (Y/W) inside the RH air bag sensor. Therefore, the voltage at Pin C208-24, Circuit 624 (Y/W) should be the same as the voltage at Pin C209-16, Circuit 617 (PK/O).
The air bag diagnostic monitor periodically pulls the voltage at Pin C209-16, Circuit 617 (PK/O), low to verify the connection to Pin C208-24, Circuit 624 (Y/W). If the voltage at Pin C208-24, Circuit 624 (Y/W), does not pull low as a result of this test, the air bag diagnostic monitor will store in memory the diagnostic trouble code (DTC) B1941 and flash a lamp fault code (LFC) 41 on the air bag indicator. If the connection between Pin C209-16, Circuit 617 (PK/O), and Pin C208-24, Circuit 624 (Y/W), is later repaired, the DTC B1941 will be stored in memory.
Possible Causes
Failure to get low voltage at Pin C208-24, Circuit 624 (Y/W), during the test can be caused by:
an open circuit in the wiring harness in either Circuit 617 (PK/O) or Circuit 624 (Y/W).
an open circuit inside the RH air bag sensor across Circuit 617 (PK/O) or Circuit 624 (Y/W).
a short to battery or ignition voltage in any of the Circuits 617 (PK/O), 619 (PK/W), 624 (Y/W), or 625 (Y/LG).
Old Apr 14, 2004 | 07:16 PM
SPELLY F150
Sorry I have a 1997 F-150 with a 4.2 5spd
Old Apr 14, 2004 | 07:18 PM
HomerWinzlow
It should be the same as the above then.
Old May 1, 2004 | 09:43 PM
brian noyes's Avatar
brian noyes
i had the same problem on my 99 expy eb p1941 now its off on its own same wiring??
Old Jan 9, 2005 | 06:48 PM
tim johnston's Avatar
tim johnston
I Have A1999 Ford 4x4 What Is Code 27
Old Jan 9, 2005 | 07:03 PM
Racerguy's Avatar
Racerguy
Hi Tim and welcome to the forum
A flashout code 27 means a problem with the PAD (Passenger Airbag Disable) switch.
The common cause is the bulb in the switch is burned out. According to Ford you have to replace the switch to cure it.
If you do a search on here I think you'll find instructions on just replacing the bulb.
Gene W
Oct 29, 2013 10:03 AM
95F150SuperCab
Dec 30, 2011 05:49 PM
whruppe
Aerostar
Jan 16, 2008 09:05 PM
nmcjg44
1983 - 2012 Ranger & B-Series
Apr 15, 2007 10:56 AM
97expl
Dec 9, 2004 08:49 PM
