ring & pinion help
Old Apr 14, 2004 | 10:31 AM
fids's Avatar
fids
Question ring & pinion help
My rear end is a ford 8.8. I need to know how the gears should mesh together. Is there supposed to be a little play between the two gears or what? I know how to adjust it and everything, i just need to know whats acceptable. Help!
Old Apr 14, 2004 | 10:38 AM
MustangGT221's Avatar
MustangGT221
You need a small amount of backlash. The gears heat up when you drive and they expand, so they need room for expansion. The backlash should be between 11-16 thousands and 77 ft-lbs on the bearing cap bolts. I don't have a dial indicator so I setup the rear end and go by feel. Hold the pinion gear and try and move the ring gear. It should move back and forth slighty, maybe 1/16th of an inch. Once I feel that it's close, I roll a tooth pattern to check it. It's really not that bad, just gotta make sure the tooth pattern is good.
Old Apr 17, 2004 | 12:30 AM
fids's Avatar
fids
thanx thats what i wanted to hear!
lauxford
Oct 18, 2012 11:57 PM
Rod Kimble
Jan 14, 2012 02:31 PM
chrisutton7770
1983 - 2012 Ranger & B-Series
Jul 27, 2009 11:43 AM
Brnco85
Jan 9, 2005 09:03 PM
YankeeFan
1978 - 1996 Big Bronco
Mar 28, 2004 11:48 PM
