Bronco II Ford Bronco II
Inertia switch (where is it, help)
Old Apr 13, 2004 | 09:42 PM
elzss's Avatar
elzss
Unhappy Inertia switch (where is it, help)
Hi, this is my first post. I got a 1990 Bii 2.9, 4X2 from a lady that said the fuel pump was bad. I got it started and drove it home (about 4 miles) It set for two days then I tryed to start it, no power to fuel pump (in tank) I checked the fuse relay under the hood, fuse is good. I got a haynes repair manual, it says the intertia switch is located under the dash on the passenger side of the firewall. I have looked every where with no luck. Thanks for any help.
ps:This is my first Bronco II and know very little about it.
Elzie
Old Apr 13, 2004 | 10:45 PM
mrshorty's Avatar
mrshorty
It's usually just under the edge of the carpet to the right of the transmission hump.
Old Apr 13, 2004 | 10:49 PM
elzss's Avatar
elzss
mrshorty, thanks will look tomorrow.
Old Apr 13, 2004 | 11:04 PM
elzss's Avatar
elzss
mrshorty, my curiosity got the best of me, so went out tonight and checked. You were right, just where you said it would be. Thanks for the help.
Old May 16, 2004 | 02:30 PM
Aggie05's Avatar
Aggie05
I own an 89 bII and it was found on the passenger side of the truck near the trany hump. gl
Old May 16, 2004 | 11:36 PM
elzss's Avatar
elzss
Aggie05
Thanks for the info, I found it. I got the B2 in a package deal, got it running and sold it. Thanks to everyone that helped me out.
Old Dec 23, 2024 | 03:11 PM
Ryan Heath's Avatar
Ryan Heath
1st Gear
I have an 89 bronco 2 someone bypassed the inertia switch and went straight to the fuel pump now my gas gauge doesn't work and the fuel pump runs all the time when the key is on I've looked everywhere for the inertia switch under the edge of the carpet in front of the transmission hump I took half the dash out I can't find it? Can someone please help me
Old Dec 26, 2024 | 07:37 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Does this help?
When the key is turned from OFF to RUN the pump is supposed to run for a couple seconds and then shut off. Usually when the fuel pump runs constantly instead of turning off it means that the computer is bad but who knows how the PO wired the pump. I’d say you need to start following wires to see what was done.
Hunt4Fun
Feb 15, 2010 11:17 AM
120kidd
1983 - 2012 Ranger & B-Series
Oct 27, 2009 12:04 AM
tink65
1978 - 1996 Big Bronco
Sep 2, 2009 01:03 AM
jablonowski05
Sep 4, 2008 03:08 AM
cvr_
Jul 4, 2005 07:10 PM
