Shifting mph
Old Apr 13, 2004 | 01:28 PM
Diabolic's Avatar
Diabolic
Shifting mph
When driving my M5OD Ranger, i notice that:
1st gear - 10 - 20mph
2nd gear - 20 - 30mph
3rd gear - 30 - 40mph
4th gear - 40 - 60mph
5th gear - 60+mph
These are the apx mph that i shift into each gear. I was curious why 5th gear handles 60 - 120mph. Seems kind of odd to me. I mean i know it's normal, but why arent all of the gears spaced apart to complete the full mph it can go?
Old Apr 13, 2004 | 01:48 PM
98xlt4x4's Avatar
98xlt4x4
Hmm. when I'm driving agressive I take first to 30mph, second to 45-50, third to 60... Just depends. Then again, I have 31" tires and only 3.73 gears.
Old Apr 13, 2004 | 03:10 PM
PSKSAM2's Avatar
PSKSAM2
The point of a transmission is to keep the vehicle in the power band (or near it) and below redline at every speed. You can shift at higher speeds for each gear and you will get to speed more quickly, but you will burn more gas.
What do you mean the "full mph it can go"? Do you think the truck will handle 120+? It will certainly not be safe at those types of speeds on normal roads.
-Jim
Old Apr 14, 2004 | 04:44 AM
mazdanotaford's Avatar
mazdanotaford
i can goto 110 in 4th
Old Apr 14, 2004 | 11:07 AM
AG4.0's Avatar
AG4.0
I have 32's and 3.73's with a 5-spd, I can go to about 35 in 1st, 55 in second, and after that I'm not too sure. At least 80 in 3rd, because I know I have downshifted to 3rd to get around trucks on the interstate and am going at least 80 when I get around. 4th will take me as fast as she'll go. So far about 115. I don't use 5th for accelerating hard because 4th gives better acceleration and will get me to my top speed.
Old Apr 14, 2004 | 03:59 PM
seth1's Avatar
seth1
this is my shifting range
1st-20 mph
2nd-40 mph
3rd-55 mph
4th-I have gone up to 80mph
5th-I only use for cruising, but no slower than 60mph
Old Apr 14, 2004 | 04:19 PM
mazdanotaford
your factory rev limiter will tell you, trust me!, 1st 35,2nd 60, 3rd 85, 4th 110, 5th gas gear, 5th will actually slow me down, if im running it hard i never get to use it, the truck seems to shut down the power anything over 110, wish i could turn it off!
Old Apr 16, 2004 | 07:10 PM
Six Iron's Avatar
Six Iron
5th gear is your cruising gear. It's basically like a direct connection to your engine, and you won't get much power at all when you're in 5th. I've been cruising in 5th on many a hilly road, and sometimes I'll have to downshift to avoid slowing down (at least, when I started driving stick.. now I know how to anticipate...) As to your speeds when you shift, all I can say is listen to your engine. It'll tell you when it's time to shift.
BIGRED 7.3L
76
Jul 23, 2013 01:56 AM
1969furd
2004 - 2008 F150
21
May 24, 2012 06:38 PM
ommegang
2009 - 2014 F150
19
Apr 10, 2012 06:32 AM
ernesteugene
32
Mar 2, 2009 10:28 PM
Danger_Dave
Mar 23, 2007 09:01 PM
