Trouble with new engine
Old Apr 13, 2004 | 03:17 AM
Josh913's Avatar
Josh913
Arrow Trouble with new engine
I just put a engine in my truck (4.9L) I rebuilt it myself, when I first started it up it ran great, so I went ahead and finished putting everything else together and set the timing. But now when it get warm, at idle it runs smooth for a minute or so and then it sounds like it misses and shakes for a split second and then idles smooth again, it does this all the time while idling, but under excelleration it runs strong with no miss. I was just wandering what you guys might think it could be, the check engine light doesnt come on or anything, could it still have some trouble codes in the computer?
Old Apr 13, 2004 | 02:12 PM
Phrogman46's Avatar
Phrogman46
Sounds like a vacume leak or a bad idle control valve to me.
Old Apr 13, 2004 | 04:22 PM
faroffthetrack's Avatar
faroffthetrack
could have set the timeing wrong? the gauge or w/e could have sliped
Old Apr 14, 2004 | 02:01 AM
Josh913's Avatar
Josh913
Thanx for the info, Ill check the vacuum lines, as for the timing I set it at 13 degrees, That is what someone told me to set it at in here.
Old Apr 15, 2004 | 01:12 AM
faroffthetrack
Stock is 10 alot of people set thiers to 12 try retarding it see if it stops
Old Apr 15, 2004 | 02:48 AM
Josh913's Avatar
Josh913
Thanx Ill try it, I appreciate the help.
weldingfreak
Jul 5, 2015 05:23 PM
tandpr
Jan 13, 2014 07:41 PM
Shernius
1997 - 2003 F150
Oct 27, 2013 06:02 PM
yewdall
15
Sep 4, 2013 10:14 PM
bdunegan
Jun 30, 2006 06:20 PM
