1978 - 1996 Big Bronco
Thermactor Air Control System? help
Old Apr 12, 2004 | 10:29 PM
kameronth's Avatar
kameronth
So I hooked the code scanner up to my truck and it read code 44. The code book says 44 means problems in the thermactor air control system. What in the world does that mean? Please help me. I did the test becuase my engine misses really bad for the first 10 min. of driving then it will dissapear after that. I can not figure it out. 88 302
Old Apr 12, 2004 | 10:56 PM
93BigBlackBronco's Avatar
93BigBlackBronco
Hey Kam
Thermactor Is Fords Big Word For Air Injection.
Air Injection Is Used On Warmup To Burn Up Excess Fuel In The Exhaust To Lower Emissions On Cold Start Warm Up.
Code 44 Definition Is "secondary Air Injection System Inoperative Right Side."
I Would Look At Air Injection System For Rusted Out Or Broken Backflow Valves At Hose Connections, Or Broken Fittings At Air Pump Hoses. Sometimes Exhaust Flows Back Into Air Injection Sytem Sounds Like Exhaust Leak.
Good Luck
Old Apr 12, 2004 | 11:40 PM
kameronth's Avatar
kameronth
Hey thanks I will check that out. Would something like that cause it to miss or at least feel that way.
88 f150
Sep 23, 2021 07:55 AM
johnburke
Feb 26, 2015 11:44 PM
Ed Bamba
Jan 27, 2015 09:21 PM
dbuck50
Oct 30, 2003 01:54 PM
chetv10
30
Oct 28, 2003 02:37 PM
