Cargo Light
Old Apr 12, 2004 | 07:33 PM
idealtrucks's Avatar
idealtrucks
Cargo Light
How do you hook up a cargo light in a truck that did not come with one...like how does the switch hook and things like that. If anyone has a wiring diagram it would be helpful. Thanks
Old Apr 12, 2004 | 07:46 PM
Mil1ion's Avatar
Mil1ion
The harness runs from the Dome Light/Cargo Light to just behind left kick panel.
You will require the special harness.
I just can't remember if it runs along the top of the door then down to the kick panel or runs from the rear door post to the floor and under the sill plate to behind the kick panel.
It's been a while.
Old Apr 13, 2004 | 11:12 AM
X-1's Avatar
X-1
Mine runs same as door switch, then up and over door to rear of cab, follows same route as dome light.
Old Apr 13, 2004 | 06:35 PM
idealtrucks
how is the actual switch and light wired up?
Old Apr 13, 2004 | 08:27 PM
Mil1ion's Avatar
Mil1ion
You need the original harness to do it properly.
Old Apr 13, 2004 | 10:21 PM
fordman428's Avatar
fordman428
id find one in a junkyard and hook that up, mil1ion is right, to do it properly you will need the original harness.
Old Apr 14, 2004 | 10:40 AM
talisker's Avatar
talisker
I got a cargo light and added it to my 69. It may not be original but I just spliced my cargo light into the dome light.
Old Apr 14, 2004 | 06:35 PM
mk's Avatar
mk
The cargo light feeds from one of those multi connectors to the left of the column behind the cluster. A wire then runs from the switch up the left windshield post and across to the light. Can't remember offhand if the ground wire runs with it or goes from the light down the left rear post to the same place the dome light ground does.
mike
Pastor Scott
Oct 30, 2016 09:55 PM
Ginther
Jul 29, 2015 02:07 PM
work.truck
Electrical Systems/Wiring
Dec 14, 2014 08:41 AM
iwals
Oct 9, 2010 09:08 PM
pickups
May 6, 2006 06:03 PM
