weight
Old Apr 12, 2004 | 06:17 PM
RiveraD123's Avatar
RiveraD123
weight
how much does the 4.9 weigh? and how does it compare to the 302, 351, and 460, does anyone know the exact weights of these engines?
Old Apr 13, 2004 | 03:49 AM
Ford_Six's Avatar
Ford_Six
It's right in the neighborhood of 600LBS fully dressed. That's more than the 302, 351W, but not the 460.
Old Apr 13, 2004 | 05:50 AM
82F100SWB's Avatar
82F100SWB
Ford Power Products lists the industrial version of the 300(carbed, with just an alternator, flywheel and bellhousing attached) at 495 lbs dry.
I have no clue what an EFI weighs, but, it's definatley not more than a 351W
Old Apr 14, 2004 | 11:17 PM
hoxiii's Avatar
hoxiii
The 300 does weigh more than any smallblock ford and almost as much as a 460, but not quite. a 302 weighs 450-500 lbs depending on the casting and a 351W weighs in right at 525 lbs or so. A 460 comes in right at 640 lbs. A carbed 300 weighs in right around 590 lbs. It's all in the block. a 300 block weighs almost the same as a 460 block.
Justin
Old Apr 16, 2004 | 12:12 AM
cdherman's Avatar
cdherman
Why does Ford have different front coil springs for the twin ibeam suspension for V8 versus 6 cyl trucks? I mean, by those numbers, you should use lighter springs for a 302 than for a 300.
Or were the old 352, 360, 390 FE engines a whole lot heavier?
jus askin'
Old Apr 16, 2004 | 03:25 AM
scroob's Avatar
scroob
302 = 450
351W = 525
429/460 = 720
The weight listed for the 460 is incorrect. That was a short block without heads or manifolds.
The FEs weighed about 650.
I put a 429 in a station wagon that originally had a 400, and the springs bottomed out after about 2 years.
429 = 720
400 = 575
So there definitely were weight ranges for springs. The motor weight is critical, since it is positioned directly over the front springs, rather than balanced out over 4 like the passenger/payload weight.
GeneGregory
Jan 17, 2017 11:40 AM
abosely
Dec 25, 2015 01:34 PM
iwanaflattie
Dec 31, 2011 06:15 AM
someday
May 12, 2007 07:32 PM
balllzzzy
Oct 30, 2002 12:58 AM
