1966 - 1977 Early Broncos
removing ignition switch, 68 bronco
Old Apr 11, 2004 | 09:34 PM
buffaloboy123's Avatar
buffaloboy123
i needto have new keys made for a 68 bronco. i have tried to remove the ignition switch without luck, even tried unsucessfully to remove the dash. anyone know haw to remove this switch? is it possible that one can duplicate the original key by using the vin?
Old Apr 11, 2004 | 09:54 PM
Mil1ion's Avatar
Mil1ion
Disconnect negative cable on battery.
Insert key in tumbler
Turn key to accessory position
Insert the end of a paperclip or small jewellers screwdriver in hole on tumbler.
Push in and turn key to remove tumbler
Unscrew the bezel from the switch.
Old Apr 14, 2004 | 11:43 PM
fordtrucksforever's Avatar
fordtrucksforever
That works on most of the two sided key switches, but this has the earlier key. You will have to push and twist the spring loaded bezel while holding the back of switch after removing the tumbler. That should do it.
Old Apr 15, 2004 | 08:46 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Fordtrucksforever, thanks for posting that! I tried and tried to get that thing off my '69 but never did.
Lordeklund
Oct 4, 2012 06:57 PM
mattri
1978 - 1996 Big Bronco
Nov 30, 2010 01:00 PM
Poison Oil Racing
Jan 20, 2009 09:50 PM
68shortbedmo
Mar 29, 2006 10:02 PM
68shortbedmo
Mar 26, 2006 09:07 PM
