Mudding
Old Apr 11, 2004 | 07:19 PM
Quackhead94ranger's Avatar
Quackhead94ranger
Mudding
i know there is an offroad board, but i am just wondering, what harm does mudding do to your engine, and what is the best way to keep your engine clean after your done mudding?? thanks, oh btw, i have a 94 ranger 4.0 4wd 131k
quack
Old Apr 13, 2004 | 01:25 AM
steven5.0stang's Avatar
steven5.0stang
Mudding is fun but costly
I got a 88 ranger that ran great before last summer, Usually the engine is not the weakest link the axles on the rangers are crappy.I spent probably close to $2000 on axles and clutches and various other things that occur during mudding. A hose kept my engine clean and that is important because of heating, If your engine is coated in mud in some spots and not in other you have variable heating where it's not designed to have heating. the worst part on you engine is getting stuck which is a part of any mudding experience. just don't overheat.
Old Apr 14, 2004 | 08:40 AM
Quackhead94ranger
so i just gotta make sure my engine stays clean? yhou just spray it off w/ a hose? is that safe?? arent u supposed to use this "simple green" deal?
quack
Old Apr 15, 2004 | 11:40 AM
steven5.0stang
is it just mud or is it grease
Mud's water soluble, so it depends If it's just mud it's alright but always have a cool engine never hot. simple green works pretty good I've never actually tried but I haven't had a problem with just a hose. I know friend s that have tried the simple green stuff. If there's mud in there it was obviously wet once already. so getting your engine wet isn't the worst thing in the world just don't spray things like your coil or distributor for any amount of time. if it's more than mud like oil then you'll definately need some sort of degreaser and i don't know all that much about simple green, whether it will take off grease and oil, but if you want to really cheap, dish soap cuts grease well just spray it with dish soap and let it sit for over night and spray it again and rinse. it should be off by then.
Old Apr 15, 2004 | 02:57 PM
Quackhead94ranger
allright i can do that! it's simple enuff!! thanks for the help man!!
quack
Dutter
1983 - 2012 Ranger & B-Series
Nov 28, 2010 11:39 AM
GeoJoe
New Member Introductions
Nov 5, 2009 10:03 AM
460
52
Mar 20, 2006 10:56 PM
BigDawg54
25
Jan 14, 2004 06:53 PM
ilranger
Jun 9, 2003 05:54 PM
