4x4 poping
Old Nov 26, 2010 | 08:38 PM
Dutter's Avatar
Dutter
4x4 poping
I got a 94 ranger, and when im in 4x4 and turn it will make a pop/thud and the rate depends on hoe fast im going, and of course im in mud or snow, now i thought it was the Ujoint on my axle but then some people told me thats normal, what do you say
Old Nov 26, 2010 | 11:09 PM
cj06's Avatar
cj06
its your front axle joints !
Old Nov 26, 2010 | 11:41 PM
Dutter's Avatar
Dutter
Ok,,, because the one on the far passenger side is a little loose, could that be it
Old Nov 27, 2010 | 12:39 AM
cj06's Avatar
cj06
most likely it would be !
Old Nov 27, 2010 | 12:53 PM
Dutter's Avatar
Dutter
alright, should i get it fixed right away or fix it when it brakes
Old Nov 27, 2010 | 02:51 PM
cj06's Avatar
cj06
if you get it fixed now you wont need to worry about it , if you wait it could brake when you are out on the trail and leave you stuck !
i have done things both ways and some times when i wait i have gotten into trouble !!
Old Nov 27, 2010 | 04:49 PM
Dutter's Avatar
Dutter
alright,, so how do i replace it once i get the axle out, i have the Ujoint but the clamps looks lock tight
Old Nov 27, 2010 | 07:40 PM
cj06's Avatar
cj06
you have to start with taking off the tire then the caliper then the rotor then the hub and then the axle will pull out , i am sure there is a bunch of little stuff also but in a nut shell that should be about it !
Old Nov 27, 2010 | 10:57 PM
Dutter's Avatar
Dutter
but what about the Ujoint its self
Old Nov 28, 2010 | 12:38 AM
cj06's Avatar
cj06
here's a picture of the axle , on the inside of the u-joint there are c-clips or retainer clips that will need to come off , after that the joints can be hammered out or pressed out .
one way is take a socket that is bigger than the joint and one that is smaller but will fit into the yoke hole , put the bigger one under the yoke so that the u-joint cap can slide into the socket as you take the smaller one on the other side and hammer the joint out !
then do the same to the other side !
here is a video of changing a u-joint from you tube , this will give you the general idea
and you can look up a hole lot more videos from you tube ( how to change u-joints on a front axle )
YouTube - How to change U-Joints without a press
http://repairguide.autozone.com/znet...3f8021b9a9.gif
Old Nov 28, 2010 | 11:39 AM
Dutter's Avatar
Dutter
ooww ok,, alright cool thanks
rdfenn3
Apr 2, 2011 12:56 PM
Dutter
15
Jan 6, 2011 09:13 PM
Father Ford
New Member Introductions
Aug 28, 2010 08:36 PM
treetrunks
Feb 16, 2010 11:28 PM
Bruker
Feb 24, 2009 05:12 AM
