460 cam question
Old Apr 11, 2004 | 01:35 PM
BillM70's Avatar
BillM70
460 cam question
I have a US Marine 460 that i got for free. It is brand new. Does anyone know how to tell what cam i have? I have the engine torn apart and was wondering if it would be worth my time to replace the cam or jus run the one that came in it. The only thing i know about this motor is it was rated for 335 hp i beleive. It has flat top pistons and the heads are 1986 models. If i do change the cam I was gonna go with the compcams extreme 4x4 cam # X4262H and get a stealth manifold and headers for it. Would this cam work without having to modify the valve spings or go to adjustrable valetrain? Also, the cam that is in it is a Ford cam but there are only a couple of casting numbers on it between the lobes and i cant find any info on them.
Old Apr 12, 2004 | 08:37 PM
BillM70's Avatar
BillM70
Well I have searched everywhere and cant seem to find any info on this motor. It has flat top pistons and big chamber heads so its prolly at least a 95 cc head I would guess which would gimme around 9.5:1 compression ratio? I am going to get the comp cams XE4262H, it has 218/226 duration with .514/.524 lift, a weiand stealth manifold, a 750 edelbrock carb and headers. Everything else will be stock for now. That sound like a good game plan? Anyone running a combo like that? Any input is appreciated, if not then i'll let you know how it works out. :-)
Old Apr 12, 2004 | 10:51 PM
greenhighboy's Avatar
greenhighboy
What are the casting numbers on the factory intake. Most marine engines came with a SCJ intake that is probably as good as a Stealth.
Old Apr 13, 2004 | 12:03 AM
BillM70's Avatar
BillM70
Yes, it has a SCJ intake, at least i think it is because the ports are huge. It is as good? Only thing is, it is cast iron. I can get the numbers tommorow
furrby
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
May 13, 2015 10:13 AM
ford460crew4x4
Nov 12, 2010 07:00 PM
F-250 restorer
Oct 5, 2010 07:24 PM
ford truck oldboy460
35
Jan 11, 2009 03:44 PM
Blown 331
Feb 11, 2006 05:30 PM
