abs light on again 89F150...help
Old Apr 10, 2004 | 10:06 AM
LesD's Avatar
LesD
R&R abs sensor at differential but lights on again after 5 miles(consistently). Would battery disconnect reset computer for proper abs function? Shop will run codes next week but before then where is location of the abs modulator? I want to give that a looksy. If this thing traces back to the computer I'll do w/o rear abs...too expensive for me to go that route.
Old Apr 10, 2004 | 10:11 AM
christaylor's Avatar
christaylor
Yes I would unhool the battery for at least ten minutes to reset the codes and then check again.
Chris
Old Apr 10, 2004 | 10:13 AM
LoosMaster's Avatar
LoosMaster
The proportioning valve is located on the inside of the L/H frame just under where the master cylinder is. The controller is behind the instrument panel above the floor tunnel. You might try disconnecting the battery for about 5 minutes and reconnecting. You should operate the vehicle for 10 miles for the computer to relearn before pulling any codes.
Old Apr 10, 2004 | 10:35 AM
LesD's Avatar
LesD
Thanks Chris. Still learning how to "dance" around on in this forum. Trying disconnect now. Will post results tommorrow.
Old Apr 10, 2004 | 10:42 AM
LesD's Avatar
LesD
Thanks Loosmaster will follow-up tom.
MHammer21
Mar 11, 2011 11:52 PM
hotrods4gary
New Member Introductions
Nov 4, 2009 10:23 AM
throwdown
Mar 23, 2009 03:26 PM
whits
1997 - 2003 F150
Jan 25, 2007 06:58 AM
ekelly
Nov 11, 2003 02:42 PM
