P0401 Code help!!!
Old Jan 13, 2011 | 11:29 AM
MHammer21's Avatar
MHammer21
P0401 Code help!!!
Hi All, Idiot light is on yet again and is reading a P0401 on a 2000 EXP w/ 140k on it. Wondering if there is a quick fix for this or if I need to R&R the EGR. Just so happens I need to smog by the end of the month...Just my luck
Let me know if you need any other information.
Thanks,
Old Jan 13, 2011 | 03:13 PM
alloro's Avatar
alloro
Remove the EGR valve and make sure the passages behind it are not blocked with carbon deposits.
Old Jan 13, 2011 | 03:20 PM
MHammer21's Avatar
MHammer21
The large ports that attach to it right? If there is blockage can you use a wire brish and clean it out or is there more to it than that?
Thanks
Old Jan 13, 2011 | 04:40 PM
Londart's Avatar
Londart
couldn't it also be the hoses going to the egr solenoid?
Old Jan 13, 2011 | 05:11 PM
MHammer21's Avatar
MHammer21
Does anyone know a post where there is some info on any of this?
Thanks
Old Mar 11, 2011 | 11:52 PM
artfd's Avatar
artfd
Comprehensive tutorial on Ford EGR / DPFE system testing & diagnosis is here Part 1 -How to Test the Ford EGR Valve and DPFE Sensor
sloate9471
Jul 29, 2016 01:59 AM
jrp79
Feb 19, 2015 09:10 PM
Courtney Williams
Jul 17, 2014 03:33 PM
Schlava
6.7L Power Stroke Diesel
Oct 10, 2012 06:32 PM
judgebc
Jan 4, 2010 12:50 AM
