All the vacuum diagrams under the hood are long gone and I'd like to hook up the EGR so it functions.
I know it can't be hooked up to full manifold vacuum or it won't idle, but what should it hook up to? is there a coolant tempature switch that turns off vacuum until the engine reaches operating temp, or does the EGR work when cold too?
hey, its 2004, might be time to learn about this emissions stuff.
this may not help much , but i dont think you need that and i dont think that truck came with a 460, egr stands for exhuast gas recirculation , which means you will need a tube running from your exhuast to the egr and then to your intake, it also involves a cat, which also didnt come on that truck so it will have something to do besides just give your engine a major vacum leak. if the engine is from a year that required those items to run right , as in a feedback carb or efi, you will need to add all of them for it to work, id be real tempted to make it run to 73 specs and avoid the expense,bob
With an EGR you can make longer pulls on a lower grade of gas with a greater margin of safety, or drop from 89 to 87 octane safely. You want that hooked to ported vacuum, so it comes on under load conditions.
I am trying to set up an EGR for my truck, but there is no provision for it on the intake. It would be nice to not have to run premium right now.
Why would it need a cat or an exhaust tube? it pulls exhaust gasses from the intake exhaust crossover. I'm just looking for the correct vacuum signal to open it up.
ported vac, thats what I thought.
ashvalentine do you have part #'s or sorces for those tampature vacuum switches?
you didnt give the year of your engine , and i was basing my statement on the possibility that it was a later model feed back or efi version.which is why i suggested running it to the specs of your truck year ,and 'ford six', are you just looking for the temp switch location,? a later year thermostate housing with the switch mounted on it would work ,and i saw a guy drill and tap his minifold for the fitting ,years ago , not recomending it though,but it did work, bob
ported vac, thats what I thought. ashvalentine do you have part #'s or sorces for those tampature vacuum switches?
Sorta. I have no motorcraft numbers (or ford numbers, either) because for reasons known only to them, they don't list the color of the valves involved. The 'cooling PVS' (for preventing overheat, so it goes off at 245) is red. A red PVS for '79 250 460 should fit yours. The Borg-warner number is EC970. (I looked for 75 460 but no dice. The 79 460 has a similar setup tho.) The EGR PVS would be black (turns on at 100 degrees) and that would be borg-warner EC901.
I said check valve up there. Scratch that. Make that a spark delay valve. (They used a check valve in two of them in '73, I'm not sure why. It would tend to hold the EGR open constantly. Bad.) For that I do have a MOT number - DY-139A (Black/Brown). That one will delay full vacuum for 1 to 3 seconds. For a 3 to 9 second delay DY-135 (Black/White). Either will buffer out any spikes.
I'm cross-ref'ing this with a '79 light-duty 460. That one uses the same setup (plus AIR pump, purge cannisters, etc.) It uses a backpressure transducer EGR valve. Those shut down at idle or full/heavy load but are otherwise open.
D8TE-9D448-JA/MOT CX-1226. You need the right spacer plate for that.
What I was referring to was the fact that my Offenhauser intake doesn't have a place to put the EGR valve. I thought about machining a pad on it, then drilling the hole for the EGR, but now I am trying to find a "stand alone" valve, that doesn't have to be mated to the intake.
I was able to use those borg warner #'s to get the switches. I have the EGR hooked up and surprize, it runs about 5 degrees cooler and i managed to get rid of the light pinging that was there on steep hills
