1966 - 1977 Early Broncos
Is it a keeper?
Old Apr 9, 2004 | 11:47 PM
ehumaui's Avatar
ehumaui
Is it a keeper?
I have a 66 with a 289. Should I put money into it or just go for a bigger engine? At this time it doesnt burn oil, and I have not taken it in to check the compression. What do you think?
Russell
Old Apr 10, 2004 | 12:13 AM
68torino's Avatar
68torino
Depends if you want to keep it stock or go resto mod. If you want to keep it stock or 'stock' you can rebuild the motor and get in the 275hp range easy. A 289 could with work be taken up to 427(look up the Munster coach) around 450 hp. You could remove the motor, rebuild and keep it for later and drop in your fav motor from 302 to FE to 460 and go as big as 800 cubes. Me I would rebuild, warm it up with some portin and polish, balanced and 'printed get it around 300hp and have a darn good ride.
Old Apr 10, 2004 | 05:36 AM
buzziscrazy2's Avatar
buzziscrazy2
kEEP IT, You can spin the 289's pretty good...........As with all fords, they can take the abuse
Old Apr 10, 2004 | 07:42 PM
akaFrankCastle's Avatar
akaFrankCastle
I'd have to agree with 68 Torino here. If you like the 66 Bronco look, and wish to keep it a stock Bronco, keep the motor. A 289 sure beats the hell out of the 170 6cyl I have in my 66. If you are looking to turn this thing into a rock/mud monster, and don't feel like spending alot of dough on building, go ahead and invest in something bigger.
And, incidentally, if you do plan on going to monster route, let me know. I can always use some more stock 66 parts for my frame off restoration.
Zac
Old Apr 10, 2004 | 09:54 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I would keep it a small block Windsor engine, whether you keep the 289 or go with a 351 conversion. A small block Bronco has plenty of power for any kind of 4 wheeling.
Old Apr 10, 2004 | 10:51 PM
ehumaui's Avatar
ehumaui
Thanks for the input...Now if I could just get it back from the body shop I could continue with the mods
Russell
Old May 17, 2004 | 04:58 PM
myddad's Avatar
myddad
Smile 289
put in a 351 windsor, it is really close to a 289-302
just a little taller and wider.
and best engine i've seen
Old May 18, 2004 | 04:59 AM
DeenHylton's Avatar
DeenHylton
I'd vote for a 351W also. Very easy conversion and capable of an easy 350 HP with more torque than the 289-302.
Deen
Patriotic Rottweiler
Feb 9, 2015 05:09 AM
leonharu
Apr 11, 2009 08:22 AM
ehumaui
Jan 23, 2004 11:57 PM
1968F250LWB
Jun 6, 2002 07:58 AM
Russell Leonhardt
Sep 6, 2000 10:00 PM
