I have a 78 f-250. It was originally a full time 4wd but the previous owner converted it to part time 4wd. What was done to this truck? It has manually locking hubs now. Is this something I need to be concerned about? What transfer case is in this truck and is the front driveline still turning if the hubs are free?
Your truck should have a New Process 203 t-case. Yes, the front driveshaft will still turn, because the t-case has no option to disengage it. The manual hubs simply keep the front axle from pulling. Concerns? None that I'm aware of. This seems to be a popular conversion, but I haven't heard if it causes any problems or not.
I have heard that the part-time t-case (NP 205) offered in these '78 and '79 trucks is a little stouter than the full-time unit, but I have no useable info on that for ya.
Thanks for the info. I also have a concern with when it is in 4 Hi it pops out when I am either accelerating or decelerating. Is this just the shift linkage out of adjustment? I did recently add an extra leaf to front suspension. I don't know if it did this before I added it but would this make a difference to it doing it now.
Does anyone know out there. I haven't taken it to a mechanic yet and really don't want to if it is simple. It is fine in 4 low which makes me think it is the linkage. Am I right?
I don't mean to scare you but my 76 was having the same problem but with popping out of 4 low loc, and the other day (while pulling out a chev) I hear a loud pop and checked it out and there was a hole in the drivers side of my 203 about the size of a baseball. I do not have auto hubs on the truck but when the t-case shifter is in between N and Hi Loc the rear driveline turns, and the front does not so does this mean that someone converted this 203?
