General Automotive Discussion
97 Pathfinder CEL...
Old Apr 9, 2004 | 09:06 PM
Dealford's Avatar
Dealford
Post 97 Pathfinder CEL...
My buddy just bought a 97 Pathfinder on Tuesday and today the CEL came on.
To just clear it by pulling a battery cable off, is the Nissan the same as Fords, remove the negative first?
Someone else told him, no, it's the positive that you remove first.
He won't do either untill he gets the correct answer.
Thanks in advance for the correct info.
Al.
Old Apr 9, 2004 | 09:28 PM
Jimmy Dean's Avatar
Jimmy Dean
I thought you always pulled the neg first, so taht you have a ground remove power first.....I also always connect jumper cables neg first then power
Old Apr 9, 2004 | 09:31 PM
AlfredB1979's Avatar
AlfredB1979
Just pull the ECU fuse in that box under the hood. Let it sit for 20 mins, the pop back in place.
That's how I cleared my Ranger--well, that Haynes says to do that.
Much better than restting the radio presets, too.
Old Apr 9, 2004 | 09:44 PM
Dealford's Avatar
Dealford
Good point about the radio. I don't know if it's one of those types that require a code or not.
Pull the ECM fuse it is then!
Thanks much.
Old Apr 10, 2004 | 03:57 AM
Ford_Six's Avatar
Ford_Six
On most Japanese vehicles it is listed as the fuel, EFI, or fuel injection fuse.
Old Apr 10, 2004 | 08:40 PM
Dealford's Avatar
Dealford
Thanks Jared, I'll try those.
DPDISXR4Ti
Oct 10, 2012 05:17 PM
brianvabeach
2004 - 2008 F150
Mar 12, 2011 08:03 PM
Marky Marc
All Things Towing
May 27, 2008 03:48 PM
Supercab
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 24, 2004 04:52 AM
cigarxtc
19
Aug 21, 2003 10:06 AM
