varying idle
Old Apr 9, 2004 | 07:44 PM
steellab01's Avatar
steellab01
varying idle
when at a stop light my 92 explorer will idle at about 10000 rpm, then drop to about 400 and stall . It did this last fall, but not during the winter. Now it is doing it again. I replaced the o-2 sensors, now the computer is not kicking any codes. Any idea that i could try, the only other prob. is lack of horse power. Used to be lots before all this.
Old Apr 10, 2004 | 02:57 AM
jclj2003's Avatar
jclj2003
first off u mean 1000 rpm not 10,000 rpm
i would suspect:
plugs and wires
vacum line
MAF sensor (cleaning)
Modulator valve
bad head gasket or intake gaskets
fuel delivery system
does this do this only when driving or in park idleing
hope this helps
Old Apr 10, 2004 | 08:57 AM
steellab01's Avatar
steellab01
Yes I mean 1000 not 10000 sorry. I already tried plugs,wires, vacume lines. I replaced feul tank, filter, and sending unit in november. I dont have any fluid leaks,would that eliminate the gaskets or no. I was looking at other threads and was thinking about trying to clean the iac.
Old Apr 10, 2004 | 11:51 AM
jclj2003's Avatar
jclj2003
yea just got me thinking the iac would do that 2 try cleaning/replace it and see what happens
Old Apr 10, 2004 | 11:58 AM
steellab01's Avatar
steellab01
well my problem turned out to be that "iac". I wish I would have found this site sooner .you guys have a killer web site ,keep up the good work. Hopefully i can add a little bit more to the mix.. thank you guys ( jclj2003)
Old Apr 20, 2004 | 10:54 AM
jbranham's Avatar
jbranham
1996 explorer will not idle
What is "iac"? My 1996 Exploer is doing the same thing.
Old Apr 20, 2004 | 12:03 PM
99Xplr's Avatar
99Xplr
Idle Air Controller.... take a look at the sticky at the top of the forum for the repair info.
Old Apr 21, 2004 | 01:19 PM
jbranham's Avatar
jbranham
IAC value
I used the sticky information and cleaned my IAC value. My 1996 Explorer is idling better.
Thanks,
John B.
Old Apr 26, 2004 | 10:32 AM
Gabriel C's Avatar
Gabriel C
Iac Sticky
Pardon my French but what the hell is a sticky and where is it located. I am having the same problem and would like to know the location of the IAC valve. Thanks.
Old Apr 26, 2004 | 10:45 AM
jbranham's Avatar
jbranham
IAC value
If you look at the start of this forum the third topic from the top is called "sticky" IAC repair.
bigbubba87
Apr 21, 2012 09:24 PM
nosebreaker
Mar 29, 2011 08:09 PM
horseracer58
Modular V10 (6.8l)
42
Dec 6, 2009 10:15 PM
jawilla
May 5, 2009 07:44 PM
damnvan
Mar 6, 2007 02:51 AM
