Changed Gears
Old Apr 9, 2004 | 11:51 AM
geno87_69's Avatar
geno87_69
Changed Gears
I have a c6 tranny, and 9" rear end.
I swapped from 3.00 gears to 3.89 gears.
How do I figure out which speedometer gear to get, so that my speedometer is close to accurate?
Thanks in advance.
Old Apr 9, 2004 | 03:30 PM
Indybroncoman's Avatar
Indybroncoman
If you have a computer-controlled car, you can have the speedo recalibrated to correct for the new gear change. Otherwise, you can change the speedometer gear. I'm not sure how much this costs but it can't be more than $20. For the gear itself, that is.
Old Apr 9, 2004 | 04:31 PM
StrangeRanger's Avatar
StrangeRanger
The formula is:
Driven gear teeth = (tire revs/mile x drive gear teeth x final drive ratio) / 1000.
You can count the drive teeth on your tailshaft and can look up your tire revs/mile at www.tirerack.com or your tire manufacturer's web site. For 235/75-15 tires it's about 722 depending on brand and model.
If your speedo was right before, then you can simply count the number of teeth on the existing driven gear and multiply by:
3.89/3.00 = 1.297 and round to the nearest integral value.
Old Apr 9, 2004 | 09:56 PM
Indybroncoman
Originally Posted by StrangeRanger
The formula is:
Yeah, what he said!
1972RedNeck
Jan 14, 2017 10:41 AM
dlfulp
Aug 12, 2016 04:23 PM
kr514
Sep 24, 2015 10:22 AM
Randle
Sep 18, 2015 08:23 PM
TBTRUCK
Sep 30, 2012 12:55 PM
