Hypertech vs. Superchips programmer.
Old Apr 9, 2004 | 11:38 AM
little rowe boat's Avatar
little rowe boat
Question Hypertech vs. Superchips programmer.
Hello I am new to the boards,I hope someone can steer me in the right direction.I am in the market for a programmer for my 2000 F350 and would like some advice on which programmer I should purchase. The Hypertech or the Superchips. Thx Lrb.
Old Apr 9, 2004 | 08:12 PM
little rowe boat
No responses,I guess that means no info out there.
Old Apr 9, 2004 | 08:58 PM
majorpecs's Avatar
majorpecs
SUPERCHIPS man.....all the way, if for no other reason than it being able to read your check engine codes and clear them for you.
Old Apr 9, 2004 | 09:48 PM
Fire Rooster's Avatar
Fire Rooster
Buy one of the following three, Predator (my choice) SCMT (another great product) Edge ( another good tuner) Stay away from the hypertech!!!
Fire Rooster
Old Apr 10, 2004 | 01:36 AM
wannaburn's Avatar
wannaburn
I run the scmt and like it just fine. I would also steer clear of hypermax
Old Apr 10, 2004 | 06:25 AM
eeglot's Avatar
eeglot
I have ran and tested both the Superchips and the Diablo Predator on my truck, they are both great, but I feel the Predator makes more power, and has more features in it that I like.
Either one would be great. Like the others said, I would not buy the Hypertech........
Eric
Old Apr 10, 2004 | 09:44 PM
little rowe boat
Thanks for the replies,this helps alot.I had heard somewhere that when you change the progamming,that sometimes problems occur and the check engine light tends to come on. Is there any truth to this and if so,what causes this prob?
Old Apr 10, 2004 | 09:50 PM
eeglot's Avatar
eeglot
Like I said, I have used both Superchips and Diablo Predator, and have never had an issue with DTC's.......
Old Apr 10, 2004 | 11:40 PM
wannaburn's Avatar
wannaburn
running my scmt on level 3 nailed to the floor I some times throw a engine light this happens at 24psi of boost this is normal for over boosting you can get a sensor that will take care of that
Old Apr 10, 2004 | 11:52 PM
little rowe boat
Where could I purchase that sensor?Thx LRB.
Old Apr 11, 2004 | 06:48 AM
eeglot's Avatar
eeglot
Banks has one, that plugs into the MAP sensor, ($10), and various others have regulators, I think ITP diesel sells one ($49). The regulator only allows the MAP sensor to see a set amount of boost, (default 22 psi). These work by fooling the control unit to think it's only making 22 PSI; therefore, it will not cause overboost, and trips lights and limit boost.
frhrwa
Computer Chips & Tuners
Feb 11, 2014 03:24 AM
1workhorse
2004 - 2008 F150
Nov 14, 2006 09:53 PM
joshtrel99
Apr 21, 2006 12:48 PM
bloomy63
Mar 12, 2006 08:17 PM
andersda437
Aug 27, 2004 07:19 AM
