2004 Ford F-250 6.0 Power Stroke Diesel
I noticed, an oil leak dripping down from the front of the transmission onto the bottom of the bell housing of the transmission at about 6,000 miles. I waited a while before taking it in to get it fixed. I took it in at about 9,450 miles to get it repaired. When I changed the oil at 6,000 I put synthetic 15W 40 Amsoil in the engine. I took the truck to the dealer I bought it from and they called Ford when they found the leak. It is leaking from the rear main. They told Ford that I put synthetic oil in the truck. They even told ford that I noticed the leak before I put the synthetic oil in the truck. Ford replied that the molecular structor of synthetic oil is different than standard oil, and that is what is causing the leak. Knowing that the 15w 40 synthetic Amsoil exceeds OEM standards. Ford won't fix the leaking rear main. Ford recommended that standard oil be put back in the truck to see if it is still leaking. At this point I am still fighting Ford to fix the truck, even though it is still leaking oil, with standard oil in it not synthetic. I have bought three new ford vehicles since 1996, and this is how they want to treat me. I call Fords customer service, and they pretty much said that if I want to I can write the CEO of Ford a letter, and maybe I might get a responce that way. Mean while I am out about $100.00 for the synthetic Amsoil and filters i put in the truck because Ford had to have standard oil put back in my truck that did not fix the leak. I am still waiting for a responce from The letter I wrote addressed to the CEO of Ford.
Tony first WELCOME to FTE, next sorry for the problems, now do a search on oil leaks here in the 6.0L forum. This will not be light reading, however it will enlighten you tremendously. Give you great insight to the problem. Stay calm and hang out here with the most knowledgeable bunch of people I have ever had the pleasure of being part of.
They will help.
So hang in there.
They will help.
So hang in there.
Originally Posted by johnsdiesel
Keep in mind the Amsoil full synthetic you are using is not API certified, which Ford requires.
They do not require that it meet or exceed API standards, they require that you use an oil with the proper API certication meeting certain standards.
Tony1347, Two things. The rear main seal on the 6.0 was a problem. I went through two and the last one seems to have gotten it right. How did the dealer know when you changed the oil and what oil you used? I don't tell them anything unless they ask.
Second, Good luck on getting a response from the CEO. I too have written a letter to Bill Ford regarding the flash they were supposed to have out over a month ago. It will have been a month on Monday since I sent the letter. I have not heard a thing other than the service manager at my dealership said he got a call from the executive offices at Ford. Customer assistance was of no help.
I think the replys so far have hit the high points. Amsoil advertises their oil as being recommended (by who?) for applications requiring particular certifications (not actually certified?). It is also interesting that they advertise three diesel oils on their site. Two synthetic blends and one synthetic (full synthetic?). All three are SAE 15W-40 grade oils. A quick look at most other "full synthetics" reveals that they are mostly SAE 5W-40. I recall reading somewhere that to be able to cover the range from 5W to 40 the oil has to be a full synthetic. If you are selling your oil as the best there is why not take advantage of the capability of a full synthetic and produce the oil as SAE 5W-40. Of course one might also ask why not sell it through retail outlets, (unless they have changed, they used to recruit individuals to sell their oil out of the trunks of their cars and their homes.... like Amway with their products.... hmmmm..... Amway.. Amsoil.. Am I being duped?) Amsoil may well be a fine product and very likely is. I must say though that they have adopted a business strategy that strikes me as strange.
Good luck Tony,
Morris
Good luck Tony,
Morris
Originally Posted by jeb
I'm not sure I'm reading this correctly. You seem to be saying Ford does NOT require the oil to meet API standards and then you say they do? Oh, I get it, I think. You're saying that it has to have an actual certification from the API rather than just an oil companies claim that it meets or exceeds, right?
Thank all of you for the info. I picked up my truck today and the dealership put regular oil back in it. Ford wanted me to put few hundred miles on it and bring it back if it still leaked. However, I drove it home 25 miles and it still leaks. I also talked to the service magr., and he told me that even though Amnsoil don't have the API logo on their product it does meet or exceed API standards and Ford will have to fix the problem. If this is the type of service I can expect from Ford motor CO., well this might be the last on I ever buy. Even though I have never bought anything but Ford vehicles in the last 10 years. Once again thanks again for all the help full info. Tony
Johnsdiesel, you are right he was very kind. However, Ford was the one who wanted standard oil put back in the truck, not the dealer. And Ford said if it still leaked they would fix the problem then. The dealer know that Ford is just giving me the runaround, that is at least what they are telling me. Thanks again
Document, Document, Document...
And now u know NOT to wait to report a problem...
at least send a certified letter to dealership with details when something first hits...
you don't know how much trouble this has saved me before...
and always ensure you type up what you want corrected wen you bring it in...
one copy for svc writer, one copy for you that the svc writer SIGNS in front of you...
and THEN you still should check the car bable they put on the svc order because 9 times out of 10 it is paraphrased "not exactly as you would have paraphrased it" !
F250_
33
08-21-2007 07:31 AM
