Any problems with the erson roller rockers? They look like a good piece. Anybody running these have any problems or suggestions? Anybody got a part number or length for pushrods to use with these? I have stock length pushrods and the only thing I'm changing is the rocker arms. Thanks
I'm running the full Erson assemblies with Hydraulic roller lifters. My pushrods are custom, ball-cup type at 8.600" overall length. That probably doesn't help you...
You may have seen that I'm have some valve train issues, but I don't think it has anything to do with the Erson parts. I did have some trouble keeping the adjusters tight early on. I ended up at about 50ft-lbs of torque on the adjuster nuts, then the problems went away.
