Draining water from filter..
Old Oct 16, 2002 | 07:27 PM
benchris's Avatar
benchris
I have a 2000 F-250 diesel that seems to have developed this fuel leak from the fuel drain mast. Do you know any way to fix the problem???
Ben
Old Dec 1, 2002 | 09:21 PM
wt may's Avatar
wt may
I have recently experienced the same problem and have not found the source of the problem. It seams to be in the drain valve itself. I do know that it will only get worse.
Old Dec 3, 2002 | 07:56 PM
bilder12's Avatar
bilder12
i have found several of the water in fuel indicator lights were shorted out right on top of the cylinder head where the wire lays along the valve cover. Follow the wire along its route and you will find the spot where the wire shield will be broken, lift it off the block and the light should go out. Be careful while doing so, if I remember right, the wire has a short tail where it is chaffed.
Old Dec 21, 2002 | 05:51 PM
edstoner's Avatar
edstoner
Old Dec 22, 2002 | 09:40 PM
marine 1's Avatar
marine 1
i have a '87 F-250. what i did was go find out where the local fire department buys there diesel,as no one wants to tick off the fireman, no problems yet.....
spow1998
Feb 22, 2011 07:03 PM
bob 2008 F250
Jul 30, 2009 12:25 PM
danshula@hotmail
Jan 9, 2005 03:03 AM
Brimhall
Jun 7, 2003 01:06 AM
barno
Mar 14, 2001 06:44 AM
