2001 7.3 will not start - does turn over.
Old Apr 7, 2004 | 10:35 PM
jac6's Avatar
jac6
Came home after work no problem. Tried to leave in the A.M. just cranked over. I checked the fuel filter, its full. the electric fuel pump reset was not popped, I swapped all the relays still no ignition. All The lights seem bright so I figured the batteries are good. Any suggestions?
Old Apr 7, 2004 | 10:42 PM
RedTaurus94's Avatar
RedTaurus94
From everything I have read on here, sure sounds like a CMP sensor. Have you tried that?
Old Apr 8, 2004 | 01:30 AM
jac6's Avatar
jac6
Thanks for the reply. Is CMP a crank senser?
Old Apr 8, 2004 | 07:20 AM
02PSD4ME's Avatar
02PSD4ME
What year is your truck? How old are the Battery's? It takes allot of power to crank up a PSD. It could be your battery's.
Old Apr 8, 2004 | 07:21 AM
powerstroker250's Avatar
powerstroker250
Cam position sensor
johnsdiesel's Avatar
johnsdiesel
It's the CaMshaft Position Sensor.
Old Apr 8, 2004 | 07:36 AM
smokinblack's Avatar
smokinblack
Check your oil. If it gets too low, the engine won't start. Probably not the problem but at least worth a try.
Old Apr 8, 2004 | 07:46 AM
bilder12's Avatar
bilder12
CPS is the thingy that is part of the timing indicator on the front of the engine down by the vibration damper. It has the pointer attached to it. Go to Intl dealer for the part and dont tell em its for a ford. Just get the part using the number on the part. You can change it yourself with 10mm socket and short extension on a 3/8 drive ratchet. Wiggle, wiggle - it comes out.
Old Apr 8, 2004 | 01:31 PM
jac6's Avatar
jac6
Headed to International will post results. Thanks
Old Apr 8, 2004 | 03:54 PM
johnsdiesel
Here's a couple helpful links:
http://community.webshots.com/photo/...84042038YpzSoJ
http://community.webshots.com/photo/...84046575HPSSqb
Old Apr 8, 2004 | 08:19 PM
jac6's Avatar
jac6
Changed Cam sensor. Did not work. Checked batteries again and found one of them showing 11.5 volts. It is Amazing that the motor cranked normally all day and the meter showed one of the batteries only a little low. Replaced that battery and it started. Thanks for ya'lls help!
Old_Crow
Feb 3, 2015 10:24 PM
eanquiel
Flathead V8 & Flathead 6
Jan 18, 2015 10:38 PM
elkarcher1716
Nov 23, 2014 04:42 PM
jwtimme
Oklahoma Chapter
Dec 28, 2013 09:02 AM
jtipton331stroker
36
Dec 8, 2011 03:51 PM
