Just bought first powerstroke
Old Apr 7, 2004 | 09:01 PM
medicman29's Avatar
medicman29
I just bought my first powerstroke, a 1999 f350 4x4 extended cab with 44,000 miles on it. this is the first one I have owned, but have spent alot of time driving ambulance's with that same powerplant. I know I'm new here, but do you folks have any Idea's of what I should be aware of as a new powerstroke owner? thanks ahead of time.
Jeff
Old Apr 7, 2004 | 09:35 PM
CAT_man_963's Avatar
CAT_man_963
Jeff
Congatulations!
Yep - come visit FTE every day and soon you'll be an expert!! Are you gonna do any mods?
Old Apr 8, 2004 | 07:55 PM
medicman29's Avatar
medicman29
Not sure. Are there mod's that will increase mileage? what mods should I do? like I said, the powerstroke's I have been driving have pretty much been stock.
Old Apr 9, 2004 | 12:07 AM
ac_fordforever's Avatar
ac_fordforever
most diesel mods increase your gas mileage. a good start will be a chip and exhaust
Old Apr 9, 2004 | 12:09 AM
johnsdiesel's Avatar
johnsdiesel
Before the chip it's a good idea to get at least a pyro gauge and an air intake like the Tymar or Ford AIS.
Old Apr 9, 2004 | 12:14 AM
ac_fordforever
the pyro wont heat up till after the chip is installed, but the 4" exhaust will take care of that. then after that the intake will be good
Old Apr 9, 2004 | 12:19 AM
johnsdiesel
Of course, but the whole idea of the pyro is to make sure you don't overheat the engine wrunning a chip or tuner. The air intake is a good idea before the chip to make sure you can get enough air for the extra fuel added by a chip.
Old Apr 9, 2004 | 01:04 AM
Shake-N-Bake's Avatar
Shake-N-Bake
MY PSD is a 99 also, has 64k when I got it. Let's see....I had to replace my Cam Positoin Sensor first.....then my multi function switch on the steering column. Both batteries died (the last two items were probably due to a horrible trailer wiring job by the previous owner) Since then.....just regular service as required..(oil change, fuel filter, coolant additive, transmission oil/filter change etc) and the truck should serve you well. If you plan on working the engine hard....get yourself some guages. Exhaust, air filter and chip normally follow next.
Welcome to FTE, drive safe, have fun.
