Carb Rebuild Question.
Old Apr 7, 2004 | 03:17 PM
MSC's Avatar
MSC
Question Carb Rebuild Question.
Where are the numbers on the carb that tells you what rebuild kit to buy? I did find a sticker on the front of the bowl. It was hard to read, but it I made out that it was made by Holley. There was a number below that, 3265-00000D as far as I can make out. It's no help though.
Thanks
Mark C.
Old Apr 7, 2004 | 04:29 PM
lastchance's Avatar
lastchance
The number they are going to want is on a small aluminum tag usually on one of the screws holding the top of the carb on. I've found quite often that on older vehicles that tag is long gone. Most carb kits today will fit quite a few different carbs. Just be careful you match the new gaskets to the old ones exactly...they are usually the only parts different inside. Just about any auto parts store will be able to give you a kit just going by application...by the truck year and engine.
Old Apr 8, 2004 | 06:32 AM
MSC's Avatar
MSC
lastchance,
Yea, the plate is gone.
Thanks for the info,
Mark C.
Old Apr 9, 2004 | 06:26 AM
ScottInTexas's Avatar
ScottInTexas
Give me coffee - Or beer!
If it is a Holley 4bbl the number is stamped into the front of the throat just below the choke plate on the right. It is the same number as on the small aluminum plate.
schoo
May 27, 2013 08:44 PM
Roller150
Mar 15, 2011 11:00 AM
66f-100
17
Jun 3, 2008 01:14 AM
bigjohng2
Nov 14, 2007 05:24 PM
dpete
Nov 11, 2006 11:55 AM
