Carb ID/model number/cfm
Old Nov 13, 2007 | 05:53 PM
bigjohng2's Avatar
bigjohng2
I've got a 1963 C600 with a 292 and a Holley carb. I need to rebuild the carb as it has been sitting over 15 years and just will not iddle.The numbers on the carb are C3TE-9510F, the list number is 2151-1 and the third # is 854. The more I search for info the more confused I get! Is this considered a Holley model 4150? And if it is how many cfm is it? Besides a rebuild kit, I need a secondary diaphram and don't know the correct part number. Can anyone help me out or tell me a good place to start looking? I also need a carb spacer as mine was cracked where the the cvg tube goes through the side of the spacer block.
Old Nov 13, 2007 | 06:46 PM
LxMan1's Avatar
LxMan1
Welcome to the forum
You would use the C3TE-9510F # for parts. I is the original 1963 truck carb.
For more help, try here. They are good about getting the info that you need.
http://www.holley.com/TechService/TechRequest.asp
Old Nov 14, 2007 | 10:55 AM
bigjohng2's Avatar
bigjohng2
Thanks for the info... I'll give it a try.
Old Nov 14, 2007 | 12:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by bigjohng2
I've got a 1963 C600 with a 292 and a Holley carb. I need to rebuild the carb as it has been sitting over 15 years and just will not idle.The numbers on the carb are C3TE-9510F, the list number is 2151-1 and the third # is 854. The more I search for info the more confused I get! Is this considered a Holley model 4150? And if it is how many cfm is it? Besides a rebuild kit, I need a secondary diaphram and don't know the correct part number. Can anyone help me out or tell me a good place to start looking? I also need a carb spacer as mine was cracked where the the cvg tube goes through the side of the spacer block.
Welcome to FTE
C3TF-9510-F = C3TZ-9510-A
C1TZ-9A586-F .. Carburetor Kit (Motorcraft CT-193) >> Replaced by >> C1TZ-9A586-G (Motorcraft CT-193-A)
B7T-9503-A .. Secondary Diaphram (Motorcraft CM-4)
B7AZ-9A589-D .. Carburetor Spacer
There no Motorcraft number for the spacer, but someone carries it, as it also fits 4V 1957 Fords and T-Birds with either a 292 or 312 engine.
EDIT: FTE sponsor GREEN SALES has both carb kits and the secondary diaphram, they don't have the spacer. 800-543-4959
>> joblotauto.com specializes in big truck parts. <<
If you need anything else, feel free to ask. I have all the parts catalogs.
Old Nov 14, 2007 | 05:24 PM
bigjohng2's Avatar
bigjohng2
Thanks For the great info Bill!
John
423billyc
Jan 13, 2013 06:04 PM
sammycooks
Mar 5, 2010 11:54 AM
77f2504by4
Jul 5, 2008 07:48 AM
jimbo81587
13
Jan 6, 2004 09:06 PM
BranMuffin
Mar 24, 2003 08:54 AM
